towing
47papa65
1994 mazda b400
anyone how much weight i can safely pull with just a ball on my bumper? extended cab,v-6
Stxrangerbumper
Ontario, Canada
B2300 / f250HD
v6 3.0L/ 7.3L
I would say not much. I only got a small trailer with nothing has tear
not to exceed 1500 lbs would be a good safe weight
Surrey
10
Vancouver, Canada
I use my ball for a tow point to pull people out of the mud, and have had no problems so far... But actually pulling a trailer?
From a quick search online, I found explorers could do 350 tongue weight, 3500 towing on the bumper ball. Try looking for something stamped in the metal on the bumper around the ball...
When I bought a ball for my bronco II bumper, it was a 3500lb ball that fit in the hole. I dont think I would ever pull that much weight on the bumper ball, but in all honesty they are pretty sturdy.
mn_smokeater
Firefighter
58
Bemidji, MN
5.4L V8
yeah the bumper should have markings showing what the safe rated load is.
also dont forget you have to stop all that so take that into account
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
keep in mind: it's not so much about the rating, but what you can tow SAFELY!
step bumper, 2000# trailer weight, 200# tongue weight. now, would i pull that much on a bumper ball... no way! do yourself a favor and just get the frame mounted hitch. new or (undamaged) used, it's so much safer and easier to use. and if you plan on pulling any trailer close to the 2000#, i'd also get some trailer brakes.
but that's just me.
AlaskanRider
keep in mind: it's not so much about the rating, but what you can tow SAFELY!.
+1 on that,
i dragged a 2 place snowmachine trailer with a couple sleds and at least 500 lbs of gear (probably more) with my 91 2.3l manual to a hunting location 120 miles away, and it was pretty sketchy on the ice. I cruised at 55 in 4th floored on the flats though.
I had very little control unless the sleds were balanced well over the axle of the trailer, and it still pushed me around alot on icy corners.
I probably could have hauled more (with some patience, 70 stock horses ...) but i would've had even less control.
My stock bumper is definately adequate for as much (and more?) than a sane person should tow with a ranger.
lil_Blue_Ford
6,192
Butler, PA, USSA
4.9L
I've seen a number of Rangers with twisted up bumpers from towing.
Me? I don't tow anything without a hitch.
My Ranger has a Class III, I bought it through Summit Racing years ago for about $115 shipped to my door.
My F-150 has a Class IV (it's not a true class, but it's sometimes used to distinguish hitches that reach farther back on the frame to mount). I got it used with one of the ears tweaked a lil for the cost of fishing it out of a scrap pile. Lil work with a torch and it's good as new.
The F-350s here both have a 5/8" thick steel hitch plate welded and gusseted to the end of the frame rails.
My dad's Ranger has a class III receiver that we put on and he's looking for a 5-th wheel hitch for it.
I have towed Bronco IIs on tow dollys behind my Ranger and I have towed my choptop along with a friend's built YJ on 34's behind my Ranger on a tow bar. The only sketchy part was trying to get going from a stop on a hill. And trailer brakes would have been nice.
I threw a 5x12 loaded up with heavy steel shelving on my bumper and went to town. Town being about 100 miles from where we picked up the shelves. Bumper is still attached and as straight as ever. Not sure of the exact poundage, but I needed low range to get moving if I stopped on even a slight grade.
