Torson diff lock
Ranger Dolly
Firefighter
NB Canada
Ford ranger fx4
How can I identify the torson diff lock on a 2009 ranger fx4 with a r8 axle
19Walt93
4,495
Canaan,NH
351
3"
235/55R16
A Torsen differential doesn't lock, it's a limited slip unit- as I understand it, it's the best one for street use and probably off road but not for drag racing. The tech library may have more info. If you question whether it's a Torsen, pull the cover, if you see clutches it ain't.
Ranger Dolly
Firefighter
NB Canada
Ford ranger fx4
Thanks for info and after reading many posts I think this is correct and the r8 axle is a very good off road set up. Just spent a couple days driving on snow and ice and my Canadian rig has very good traction.
rubydist
867
Denver
Ford Ranger FX4
The Torsen rear axle in Rangers is the large bearing, so the flanges on the ends of the tubes are larger than on all the other Ranger axles (which are small bearing), so there is no need to pull stuff apart. The only way a Ranger got a factory large bearing axle is with the Torsen diff.
Ranger Dolly
Firefighter
NB Canada
Ford ranger fx4
Thanks and I am very pleased to learn my new to me Ranger has this robust set up
pjtoledo
3,003
Toledo Ohio
Fords
3.0 2.3
until 2010 and 2011 came along. they have big bearing, big disc brakes, 28 spline open diff rear axles. but no provision for the tone ring & it's sensor.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Just a tech note, 2010-2011 diff will accept older carriers. Stuffed a 1994 LSD carrier in my 2011 because I'm too poor for a torsen. Fit just fine when I swapped ring gear and took the tone ring off.
fastpakr
2,845
Roanoke, VA
From a 28 spline axle?
Ranger Dolly
Firefighter
NB Canada
Ford ranger fx4
I had a 2010 2wd that would get stuck on a wet leaf
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
rubydist
867
Denver
Ford Ranger FX4
Good to know, I've never actually taken a good look at a 10 or 11 Ranger...
Ranger Dolly
Firefighter
NB Canada
Ford ranger fx4
The one I have is an 09 fx4
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
TRS 25th Anniversary
12,783
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
The axle is just different enough that you have to be careful what you get for it. The differential itself is pretty much same same with any other 28 spline axle aside from the bearings.
The brakes are pretty much unique to the Ranger from what I’ve seen. The Explorer Sport is close but the rotors are non vented. I haven’t seen the brakes on a regular Explorer to say if they are the same or not. It’s possible they have the same rear disc brakes.
pjtoledo
3,003
Toledo Ohio
Fords
3.0 2.3
the 10-11 also have the boss for the watts link pivot. It wasn't threaded on the one I regretfully purchased.
smilinjack
34
rochester, mi
ford ranger
408C
2"
Always bite off more than you can chew!! :)
Torsen is 31 spline
