Tires/lifting
'99 EB Explorer
55
Sudbury, Ontario, Canada
I can't remember the brand, but I was looking into 2" "lift" shackles that are made for jeeps. I was told they'll fit the Ex perfectly. As for the front....not sure with yours.(i have the option of cranking the torsion bars on mine)
As another option...have you ever considered a 2" body lift? I'm told that they're MUCH easier and cheaper than suspension lifting.
4.0B2
151
Walls, MS
4.0 v6
no torsion crank on the 92
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
And you cant add blocks because the Ex is spring over axle.
tjs4x4
ID
Ok, so now the other question, would it be worth just doing the suspension lift, or would I be better off doing a body lift as well, and if so, how does that happen?
disciplerocks
53
Evansville, IN
If you are only going 2" you could do either. If you want more, I would go for suspension and upgrade brackets and radius arms for better performance.
tjs4x4
ID
Damn. LOL. There goes my inexpensive lift haha. What about body lifting? I've not seen it done, but if that's easier, I'd rather go that route.
disciplerocks
53
Evansville, IN
lol oops, I meant spring UNDER.
kolton
U.S. Military - Active
lewisville, Tx
Body lift is going to raise the body higher off the frame. So your not gaining any kind of clearance frame wise, but it will allow you to run larger tires.
tjs4x4
ID
Dang it. Now I really don't know what I should do haha.
4.0B2
151
Walls, MS
4.0 v6
Add a leafs.. Shackles..
tjs4x4
ID
Adding a leaf spring? How many would I need to get 2-3 inches of lift? Ok, then the spacers/washers for front end? What are shackles? How do they fit in the picture?
4.0B2
151
Walls, MS
4.0 v6
Shackles are what holds your leaf pack to the frame. Beltech 6400 chevy drop shackles workbas a lift shackle for our fords. Add a leafs can't be done bc by the time you get enough for that lift it will ride so stiff an have NO flex
tjs4x4
ID
Ok so now im lost. Why suggest something if its not going to work?
disciplerocks
53
Evansville, IN
But they wont work for an Ex. The shackle goes around the frame instead of having a separate bracket on the side.
4.0B2
151
Walls, MS
4.0 v6
Bc I'm tossing out ideas then I realize it's not gonna work... Sorry
