timing with pinto dist
Broncodude
Kentucky
I can't find the total advance needed in the 2.8 with the pinto dist. Initial timing would help to(without vacuum line hooked up). Its running at 8*btdc right now. Just want to get it dialed in before I break in the engine.
skippy
38
Georgia,USSA
2.8l durasparked rice killer
the 2.8 is supposed to be timed at 10 degrees btdc initially w/vacuum advance plugged.i wouldn't think that it would be different w/duraspark.
Broncodude
Kentucky
ok, I'm pretty close then. Thanks
skippy
38
Georgia,USSA
when in doubt check the tech library,jim has updated the engine info and there is a lot of essential info on our little 2.8l engines.i'm not far behind w/duraspark,i'm doing research now and trying to save money.
Broncodude
Kentucky
I used MSD 6al to fire things. If you've ever had an engine with one of these, you'd love them. This was first on my list.
small ranger
dirty south
171 c.i. of fury
I run 15 deg btdc on my truck with a pinto dizzy
Broncodude
Kentucky
small ranger, whats your total advance running?
85_Ranger4x4
17,884
SW Iowa
I have mine set at 15 degrees, it can be kinda hard to start when it is warmed up (harder than it was with the feedback stuff) I am going to change it to 10 degrees and see if that helps.
small ranger
dirty south
171 c.i. of fury
15 deg btdc is what I read on the timing index with the vac advanced disconnected at approx 700-800 rpm.
Broncodude
Kentucky
small ranger, what I was asking was about your total timing...Initial plus advance in distributor equals total advance at 2500-3000 rpm's ?? It should be 35-38 degrees or so..
