TIB Moog Camber Bushings ONLY Deg + Camber Allowance on the chart
henryj10
Everett, WA
2.3 140cid
Moog Camber Bushings ONLY 2 Deg Positive Camber Allowance on the chart
I am leveling my front end on my 96 TIB 2wd 2.3L with coil spacer, bought moog camber bushings but the chart for it says only allowance 2 degrees positive camber play. will 2 degrees positive camber and 4 degrees caster either way+/- be enough to get realigned from your guys experience I wanna get the right bushings before I dig myself in a hole with the tires suffering.\---/
P.S. the chart it came with does allow for +/- 4 degrees camber on the 4x4 TTB 4x4 chart, could I use that or are either of the charts useless, should I just turn the head until its flush and mimic it on the other side.
Thanks,
Jason
Duane867
9
Columbus
2.3L
I would call thier tech support if it were me...
