Bronco638
- Apr 14, 2014
- 5
- Chicago-land
- Ford
- Engine Size
- 3.0
Thanks for the feedback but the Bilstein units are outside of my budget.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
I think you might be right.monsterchuck said:I notice you said you had LT tires on your truck. That can definitely cause rough riding issues on a vehicle as light as a Ranger. What load range are they? You can change shocks, but it might not help as much as you hope.
I guess it depends on your definition of 'expensive'. The Bilsteins I found for my Ranger were about $100 each. I can't afford to be that picky. I'm happy for you that you can be.6.2 said:Bilstiens aren't that expensive. Sounds to me you can't afford to be picky. Run what you have.
It wouldn't take much to improve over shot original. I am very happy with my nitro skyjacker shocks, hands down better than what was on there... With lt tiresI guess it depends on your definition of 'expensive'. The Bilsteins I found for my Ranger were about $100 each. I can't afford to be that picky. I'm happy for you that you can be.
I run 25 psi with 255/70R16's P metrics, not LT tires. They still do not contact the road at the outside edges of the tires! You may get better mileage at 35psi but I bet you are burning the center out of those tires and getting a bad ride from them.I'll take a look at those mount insulators. However, I would not be surprised if they're in good/great shape as this is a southern truck. However, just because the truck is from down south doesn't mean they're not getting tired.
At this point, I think it might have more to do with the tires, load rating and the fact there's 35 psi in them. I am getting ~18 MPG though.....
I wonder what taking one leaf, out of each leaf pack, would accomplish.
I have ran 30psi in mine for 14 years... tires wear fine. Load range c tires ride fine too.I run 25 psi with 255/70R16's P metrics, not LT tires. They still do not contact the road at the outside edges of the tires! You may get better mileage at 35psi but I bet you are burning the center out of those tires and getting a bad ride from them.
Note I air-up if I am carrying anything of wieght in the bed and won't carry heavy loads. I don't need the load rating and bad ride of a "C" rated LT tire do you?
I would assume you are running stock size tires, rotate as required and maybe have some weight in the bed??I have ran 30psi in mine for 14 years... tires wear fine. Load range c tires ride fine too.
I put-in an extra 120lbs, two of the "Tube Sand" bags made for the purpose and over the rear axle. It helps a bunch. Lowes or Home Depot has had them in the past.I wonder what ~200 lbs. of sand, over the rear axle, would do. Winter is coming but the truck does have 4WD.
