Third brake light in way of camper shell
TechmanDan
Chino Hills, CA
Howdy. I've got a 2002 Ranger XLT Extended cab and I got myself an aluminum camper shell at a steal today.
My issue is my third brake light; it sticks out too far from the cab. I need to do some work on it anyway to attach the third brake light in the camper shell, but I need ideas for making it shorter, so it doesn't stick out so far.
I'm not looking to spend $100+ on a fancy new third brake light because I won't use it. I'll keep the one I have and put it back if needed when I take the top off though.
Ideas?
snoranger
Professional money waster
ASE Certified Tech
13,677
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
"Adjust" the cap with a hammer, so it will clear the light. Its only aluminum. :D
02RangerXLT
53
NE
TechmanDan
Chino Hills, CA
Really? Come on... there's GOT to be brighter ideas than that...
ashleyroachclip
1994 Ranger STX
1995 Explorer L
I would use a socket off a similar light and lexan to build a light .
snoranger
ASE Certified Tech
13,677
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Sorry, I thought you were looking for the cheap way to do it.
Lots of projects to do, little $$ to do them with.
Idea #1: (I'm assuming you want to be able to reinstall the light if you remove the cap)
Remove the light, push the wires back into the hole. Cut a piece of sheet metal to the size of the brakelight. Curve it on a slip roller to the same curve as the body. Paint it, install with silicone and screws (in the original holes.)
Idea #2:
Cut the offending section out of the cap. Form a new piece the right shape to clear the brakelight. Tig weld it into place. Paint it. That's a brighter idea, if you own a Tig welder.
And with the right tools and talent, my idea of "adjusting" it with a hammer will look like it came from the manufacturer that way.
DriverSideImpact
Milwaukee-ish, WI
2.3L
This was my first thought too.
In addition to that, you could drill a small hole in that sheet metal, run extended wires through it (seal with a small rubber grommet), and run that back to the 3rd brake light on the cap.
You could use some nice crimp-on male and female plugs on the extended wire and 3rd brake lights. That way when/if you take the cap off you can just unplug it and plug it back in on the cab.
You might even be able to figure a way to reuse the stock 3rd brake light on the cap. The you don't even have to buy a new light.
TechmanDan
Chino Hills, CA
haha, thanks guys.
The camper came with a 3rd brake light, which i'll use. I'm mulling over how to modify the existing third brake light on the cab so it's still usable, but out of my way.
the cap is old so I don't want to mess with it and cause any major issues, and it's really cold outside so I don't feel like working out there for long.
it's a piece of a bigger project, and i'm still working on getting it all together.
06RangerXLT
54
Georgetown Ontario
haha, thanks guys.
TAKE OUT YOUR BED LINER, LOSEN THE BED BOLTS AND PULL IT BACK A HALD INCH OR SO SO THE BED SITS FURTHER AWAY FROM THE BODY. THEN TIGHTEN THE BOLTS AND BE DONE!
JUST DID THE SAME THINGS ON MY FRIENDS TRUCK. JUST TAKE YOUR TIME ALIGNING THE BODY UP SO IT LOOKS STRAIGHT. :icon_thumby:
TechmanDan
Chino Hills, CA
Yet another thread I failed to reply to, sorry about that!
I ended up modifying the camper shell slightly to fit, and shortly after the camper shell ended up on my Dad's '99 ranger, and my bed cover went back on. I checked with my Dad, and the shell is still working well!
