B2Binky
- Mar 25, 2017
- Reaction score
- 0
- Location
- Pine Mountain Club, Ca
- Make / Model
- Ford
- Engine Size
- 2.9l
- Manual
- My credo
- “Today a young man on acid realized that all matter is merely energy condensed to a slow vibration,
An introduction to me and my second recently acquired Bronco II-
I might have found the greatest deal on any Bronco II, ever. It was purchased in 1990 to be towed behind and RV, and only got about 50,000 of actual road time before I got it a few days ago for $350... with 157k on the odo. It starts right up, passes smog, and has manhandled the 90-mile long 6,000 ft climb to and from my home from Los Angeles three times now, cruising at a steady 70mph uphill no problem. The only flaw was that the turn signals didn't work, so she stopped driving it. One $10 relay later, they work perfect. Am I in heaven??? It passed California smog!
Everything is clean, it doesn't consume oil or coolant outwardly, suspension is great, it *supposedly*, based on it's 12/89 production date, has the Dana 35 front axle, even though it looks like a Dana 28 to me. WHAT AM I GONNA DO WITH ALL THIS???
-Known Issues-
-parking lights stay on sometimes, even when the key is out. I'm currently researching solutions and have found this is brown wire, and is probably shorted to ground somewhere. Wish me Luck
-Rear tail gate knob and hydraulics somehow destroyed. Might be a junkyard find, but doubtful. Do any other Ford models have these you may know about?
-All three rear view mirrors are garbage.
-Rear Antilock Brake light is on- suspected module swap should do the trick.
Future Mods:
First things first, the 8.8 rear axle with a rebuilt Dana 44 in it, and chromoly axles that bypass the c-clips. Super duper disc brakes all around, new brake lines and cylinder, and of course, a beefy differential cover and some purty paint.
Then, the front axle being a 28 or a 35 yet TBD, (I swear it's a 28 but it should be a 35, it may have been swapped previously), rebuilding the front as a 35 with similar treatment. I'd like a slightly wide stance on both axles.
Big Bad 30" tires all around BOOM!
Already have a steering stabilizer.
Then your standard complete fuel and evap system rebuild, cold air intake, phatty headers and magnaflow exhaust and cooling system revamp beefup. No biggie.
Then, and only then, will she be ready for the LIFT KIT. Nothing too big, 3"-4" Max. Leafs, coils, pistons, the whole nine.
In the future I'd like to swap the Mitsubishi transmission with a Borg Warner T-19, and find a suitable pairing to a later model Cologne 4.0L. But I think right now, keeping the powertrain stock and ultimately reliable is the way to go, at least it will get me through this next winter (The snow hasn't even melted yet and I'm already worried about my vehicle for next winter). But summer in the Pines means world-class off-road fun is literally at my doorstep. Let's beef this bad mama jamma out
-Known Issues-
Future Mods:
