Tach install issues
B2_driver
Crawfordsville, IN
1990
199
some v6, some v8, 3.9 cummins
do unto others as they do unto you
I have swapped in tach clusters into several rangers before with no issues but my recent truck has me confused. I have a 1996 non tach 3.0L. I installed a cluster from a 1996 explorer with tach 4.0L. Not sure if it doesnt read correct because it isn't for a 3.0 or if I have another problem. it reads about 1200 at idle and it is actually at 800. by the time it reaches 6K on the tach it is only at 4K by the OBD data feed. any help is greatly appreciated.
SenorNoob
575
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Strangely enough it sounds like that tach is configured for a 4 cyl. I wonder if the second ground wire wasn't connected because it originally had no tach?
At least I think the newer ones work that way. I'd look into what it takes to change from the 4cyl to 6cyl or vice-versa.
Rangerslpr
tach
I am having the same problem. I have a 96 ranger 3.0 5speed nontach and replaced the dash with a tech version from an 98 ranger 3.0 5speed and it is about 800 rpm off. Same engine trans combo. Where would the second ground be?
