superlift k700
kyle1990ranger
Hey guys. Iv decided to go with the 5.5inch superlift for my 1990 ranger.was wondering what your opinion on it was and if there are any issues with driveline angles. I have the 2 piece rear drive line. Also any other parts I might need or recommend. brake lines?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Have you read thru the suspension reviews post at the top of the section here?
Welcome to the forum, by the way :beer:
kyle1990ranger
Yeah a little didn't see much about the drive lines
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
If your truck is a Supercab, a swap to the later 1-piece rear driveshaft generally makes things go a lot more smoothly.
Some info here:
http://www.therangerstation.com/Magazine/June04/offroad.htm
Front driveshaft should be fine.
My preference has long been for Skyjacker's kits, followed closely by James Duff. Both these kits seem to have the strongest components by far. Tuff Country makes a decent budget-minded kit if the above two are out of price range. I continue to see a lot of cracking problems on most other brands of lifts.
kyle1990ranger
Other than the driveline Is there anything els I would need ? Brake lines etc?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I think a majority of kits do not include brake hoses because Ford made a couple changes over the years on Rangers. So you'll need to get the correct part number hoses for your year.
To be sure though, look up the contents of the kit you're interested in on the manufacturer's web site.
Another item I recommend is Skyjacker's pt# FA600 drop pitman arm. The arm that comes in most kits sucks (doesn't drop the steering down far enough leading to problems with handling and tire wear).
kyle1990ranger
who would you recomend to get the hoses from?
