Suggestions for stripped Dana 35 bolts
_Kyle_
Toledo, OH
Well, from wheeling the exploder, I managed to strip one of the bolts on the front of the Dana 35, presumable from bashing it on a rock. I know of a few others that have done this before, and used various fixes. I'm sure this is a fairly common issue so, so what would be the best way to take care of it?
Right now, i'm thinking to either:
- Drill and tap them bigger and run new bolts in them all
- Find a Heli-Coil and use that for the stripped ones (leads on sizes/kits?)
As it stands now, I tightened up the rest and it's not leaking but I feel like this will cause me a headache down the road.
Thanks
-Kyle
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
The heli-coil is the best option. I'd drop the diff and do them all while I was at it.
_Kyle_
Toledo, OH
Would either of you have specifications of a heli coil that would work for this application off hand?
4x4junkie
585
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I believe it's M10 - 1.5.
Yes, do ALL of them. Best thing you can do. :icon_thumby:
Also, throw a skidplate on it too if you run in rocks a lot. Repeated bashing does slowly distort the cover (beam) slightly which can cause it to seep oil.
_Kyle_
Toledo, OH
Thank you very much. I will do some digging with McMaster Carr or something to find some heli coils and I will replace ALL of them.
I will also have to look into a skid plate of sorts because I do like the rocks. :icon_twisted:
_Kyle_
Toledo, OH
So many styles on McMaster Carr to choose from - any suggestions on regular style vs locking?
scotts90ranger
4,605
Dayton Oregon
2.3 Turbo
go to Napa, they have an assortment of the standard coil type in a packet with the tap and install tool and everything, not cheap, but will get you what you need
_Kyle_
Toledo, OH
I will have to check into that. I figured it wouldn't be a terribly cheap fix, but it's needed regardless and probably the easiest/safest bet for future use.
scotts90ranger
4,605
Dayton Oregon
2.3 Turbo
it's not that bad, probably $20 for 5 inserts and the tap and stuff, then a few bucks more for more inserts...
_Kyle_
Toledo, OH
5/16 UNC
I did all of mine and have not had any leak issues.
Where did you pick up your stuff from by chance? I think i'm gonna fix mine next week after I go wheeling.
crawlin91
60
Crawlorado
2.9, 4.0
CopyKat
5/16 UNC
Both of you know your stuff. Which is it?
CopyKat
8
Manitoba, Coldest place in Canada
Factory is an M10-1.5.
Sorry it was 7/16-14(UNC) it is Blonde one larger than the M10. The 4.10 Diff I installed had the lower 5 bolt threads stripped from a gorilla over torqueing the bolts. I needed longer thread for my beams, so I re-tapped all 10 of the mounting threads 7/16-14. I was able to torque them to the recomended 35 Ft.lbs.
crawlin91
60
Crawlorado
2.9, 4.0
thanks. I was looking for the helicoil kit at ACE. I found it to work in the M10 1.5 but the clerk insisted it was a standard size.
