sub question
mattr87
roy, washington
last night i installed my amp into my 87 ext.cab. i have a two channel 1200watt amp it works fine but i put my sub in its a jl audio w1 but its in a smaller truck type box but it sounds like crap. when it hits its kinda distorted it kinda has a good rumble. is it my sub or my amp or box? :mad:
koda6966
61
The green part of NY.
Is the box the right size for the sub?
mattr87
roy, washington
yeah, its just that the box is made for going behind a seat and its preety small. i was thinking a bigger box would let the sub perform better
koda6966
61
What size box does the manufacturer of the sub say to use for that particular sub?
If you don't know, I could find out for you quite easy. Just tell me the size of the sub.
mattr87
roy, washington
its a 10" jl audio 10w1v2
koda6966
61
hmm.. I'm pretty sure your supposed to run those with a sealed enclosure of .75 cubic feet, or ported at 1.5 cubic feet.
Whats your current setups size?
mattr87
roy, washington
umm. I dont know. Il go see
Pistons23
Fresno CA
2.5
nope, according to jl's site, they specify .625 cubic feet sealed. 1 cubic foot ported. if its sounding distorted, you may be pushing it too hard. it should be fed 300 watts max.
koda6966
61
Actually, I checked using their site as well. Double checking right now.. will edit in the results.
--Results--
I'm right.. your not.
What site did you use? My guess is you looked up a random 10inch subwoofer, because the W1 is actually discontinued. Although if you know what your looking for, you can find it.
Jason
28
(formerly) 200
The box is likely too small. Try turning the amps gain down for the time-being. It will help it sound better.
Pistons23
Fresno CA
2.5
mattr87
roy, washington
yeah my box is deffinatly too small. im gonna just get two tens in a bigger box.
