Stupid obd1 question
OldJunk
Springfield OR
1984ish
2.8l V6 (Home Rebuild!) 2100 motorcraft carb
On obd2 cel stays on until problem is corrected/cleared. On obd1 cel came on briefly and went out,no problem with vehicle runs great in all aspects and cel comes on/off at start cycle. so does the cel only come on when a cond is pres. and goes out if cond. subsides ? is there a code stored ? just wondering, truck is a 93 F350 w460 E4od
Wicked_Sludge
43
Westport, WA
3-point-GO
the CEL comes on when a sensors input is percieved to be outside of an acceptable range. if the sensor corrects itself, the code is stored and the light goes out.
OBDII vehicles are the same way.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
OBD1 only stores a code if it stays on longer than 30 seconds. OBD2 stores a code as soon as the light comes on.
OldJunk
Springfield OR
1984ish
THANKS!!! I not going to worry about it now, it happened over a year ago, for maybe 20 sec at hwy speed and has never reoccured since. someone was talking about obd1 and it jogged my memory. I guess im over protective of it beacause its the " flagship" of my fleet w/ only 22,000 miles.
Wicked_Sludge
43
Westport, WA
3-point-GO
if the battery hasnt been unhooked since then, you could still pull the code just for fun.
Wicked_Sludge
43
Westport, WA
3-point-GO
i dont think so. sensor baselines and multipliers are stored for the past 80 drive cycles...but i dont think trouble codes go away until cleared.
OldJunk
Springfield OR
1984ish
Must not be anything wrong, mpg lately have actually gotten better. Im now getting 12 mpg!!!!!!!,instead of 11 WOW!!
Wicked_Sludge
43
Westport, WA
3-point-GO
ya "fuel efficient" and "big block" dont generally occupy the same sentance. but you can pull just about anything you want from gas station to gas station :D.
Psychopete
29
FW, IN
Ah, I was slightly mistaken:
(Technical Library)
These codes are kept in memory for 40 warm up cycles. To clear the codes for purposes of testing or confirming repair, perform the code reading procedure. When the fault codes begin to be displayed, de-activate the test by either disconnecting the jumper wire or releasing the test button on the hand scanner. Stopping the test during code transmission will erase the continuous memory. Do not disconnect the negative battery cable to clear the codes; the keep alive memory will be cleared and a new code (19) will be stored for loss of PCM power.
Perhaps this bit of information is incorrect?
Pete
Wicked_Sludge
43
Westport, WA
3-point-GO
ahh, well there ya go.
OldJunk
Springfield OR
1984ish
Truck gets 12 unloaded w/ canopy on it. 10.9 w/ 2,200 lb camper, towing an 18ft boat hwy mpg. better than my old 460 w/ holley 4bbl 77 f250, it got 8mpg.
MAKG
19
California central coast
The quote was fully consistent with the Ford emissions manual for 1991. But of course Ford manuals aren't 100% reliable either....
But I certainly have seen that #@@$%^$#^&%$&%&*%( KAM code myself.
