Stubborn Ball Joints
kunar
131
Toledo, Ohio
5.8l
I finally decided to do my ball joints on the pass side, i have been really busy so i haven't had a chance till now. i have everything stripped down to the knuckle but i cant get the ball joint studs to break free from the axle beam. i've already put lots of heat on everything along with a good soak of PB Blaster, anybody have any ideas? on the last set i did, i just whacked stuff with a big hammer but its not working on these today. i guess the next thing i'm thinking is a pickle fork (i don't have one) anybody have any other suggestions?
rickcdewitt
5
nor-cal
4-0 swap
i used a long pry bar and a hammer.have someone pry the knuckle down(without bending the axle beam) with all their might and try and smack the top of the lower ball joint stud with a big drift and BFH.the top shoulden't be stuck as bad.if you put a sacrificial nut on the stud and use a brass drift it won't deform as much.
kunar
131
Toledo, Ohio
5.8l
just got back for doing some running and it literally took about 2 mins with the pickle fork. i got both autozone had and ended up using the one they call a pitman arm fork, the tie rod end fork was too small. just pound it straight in like a wedge and it popped apart.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Glad you got it. Nice how the right tool for the job makes it so much easier!
kunar
131
Toledo, Ohio
5.8l
heh, yea i guess. ive never been a fan of pickle forks, there constant ripping of tie rod boots and all, but i guess if youre replacing them it doesnt matter if they get torn. that and the fact that the last 2 sets i did, i just used a big hammer to knock them off...
DangerRanger96
T town Toledo
Hey Kunar, what year ranger are they on? I have a 96 that I'm thinking of doing.
kunar
131
Toledo, Ohio
5.8l
mine was an 87 (d28) yours will be a d35 but should be similar, i know yours will use a pinch bolt on the top stud where mine is threaded to accept a nut. all in all not difficult. strip the knuckle of all steering, brakes, bearings etc. unbolt the ball joints and knock stuff apart, try a pickle fork they are great! get a press ($100 loaner tool at autozone or on sale at harbor freight for $30 right now) and pop things apart, install in reverse order. there may be a write-up in the tech library
