I still suggest a SuperRunner, then mod if down some if you need to lower the tie rods.
Then if you get real serious and need extra beefage, the SuperRunner is super easy to make beefy. Buy a M22x1.5 RH tap, one RBV passenger side TRE, one RH Chevy TRE, one LH Chevy TRE, one RH Chevy DRE, one LH Chevy TRE, Ream out the holes on the centerlink for the new chevy stuff, put the rod ends on, measure for tie rodes (center to center) call up WFO and they will mill out some heavy duty DOM tie rods for you and when you are done you have:
a 3/4 ton/1 ton SuperRunner setup
almost no bumpsteer
and a replaceable TRE on the centerlink (the one to the pitman arm)
This is what I did, and I couldn't be happier. If you wanna do this and have questions, I have it all documented with pictures, part numbers and dimensions. Beefy, and great for commuting. Best of both worlds:
