Well it sounds like im just gonna have to get use to the bump steer. Thanks for all the info. Just out of curiosity, how is the the superrunner kit with bumpsteer?
It is still there, but it is drastically less (now that the pivots are where they should be since I modified it)...I really only notice it b/c of the amount of travel I have compared to stock that gets used when driving. About 4" of travel gets used in normal highway driving, so bump-steer is almost non existent then, very much like stock so to speak. Offroad, when going fast, or coming of a ledge and utilizing more like 5"-11" of travel, yes, the bumpsteer is still there obviously since at the extremes the tie-rods don't exactly follow the same arc as the beams, but it is very minimal.
However, the bump-steer is way less than what it was. It used to be so bad that I would eat through draglinks about every 20k miles, since the TRE at the pitman arm was operating at a extreme angle, and getting huge axial forces constantly. From an engineering standpoint, flat tie rods mean that the forces are less since the bumpsteer doesn't exist, and aren't pushing/pulling on that joint with that large magnitude of forces anymore.
I've run stock, with a 2" drop arm, which was horrible @ 3.5, 4, & 5.5" of lift.
I've run stock, with a 4" drop arm, which was better, up to 5" of lift.
I've run a 1-ton chevy TRE version of the StoneCrusher setup, which still had unacceptable amounts of bumpsteer, with a 4" drop arm @ 6.5" of lift.
I've ran a stock style setup, using 1-ton chevy TRE's which wasn't too bad, but still sucked in general, and left more to be desired, on a 4" drop arm @ 6.5" of lift.
I've run a SuperRunner kit, with an UN-MODDED centerlink, and 1-ton TRE's and a 2" drop arm, and that sucked, though I will say that less bumpsteer was perceived since the tie-rods are nearly equal length and the forces almost balance each other out if they occur at the same time. Still not good though. This was @ 6.5" of lift.
NOW I am running a SuperRunner kit, with the centerlink pivots dropped 2.5", to match my lift bracket pivot points, 1-ton TRE's, and custom idler arm, which makes the tie-rods FLAT. THIS is by far the best system to date. Drives like stock on the highway, with minimal bumpsteer offroad. And it has this little added side benefit of being beefy, durable, and simple to work on or replace individual components. I can get pics if you want...or if you do a search they are floating around on a few threads. Still @ 6.5" of lift.
I have run 4 different systems, and I will say that the modded SuperRunner gave the best results. For me the StoneCrusher didn't work b/c of my lift height, but it should work no problem for the 2-4" lift range. It may sound like I am biased towards the SuperRunner thing, which I am, but this is only b/c of the amount of lift I wanted to run, for shorter lifts, other styles can work just as well.
Just remember, the pivot(s) for your tierods, must be no more than about 1" in vertical distance from your drop bracket pivot points.
See the very last picture @ the bottom of the page here:
http://www.therangerstation.com/Magazine/winter2008/steering_tech.htm
IMHO, single best article here on TRS ^
