steering box ????
tmaxxman
PA
2.9L
ok my brothers steering box got a bad leak from under the pitman arm the ??? i have is there a seal under the pitman arm he can replace or what ?????:icon_confused:
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
yes i did one 10 years ago or so. if i remember right the kit was under $20. the hard part was removing the pitman arm
tmaxxman
PA
2.9L
sweet thank a lot
tmaxxman
PA
2.9L
ok one more ??? how would i get the pitman are off is there a puller or can you use a hammer
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Buy/rent a pitman arm puller.
4.0B2
151
Walls, MS
4.0 v6
yeah... don't use a hammer, it makes it leak more sometimes lol.. i think the kit is a little more than $20 now tho. i need to get that kit and installed in mine.
Sighman
04/2011 & 04/2014 MTOTM Winner
MTOTM Winner
Canton, TX
302
Its a pain to say the least to get it off, I did mine about 2 months ago and its leaking again..Time to replace the whole darned thing!
jhammel85
Guest
Try the kit and get a puller if you want to. BUT..If it's leaking now, theres a decent chance that the shaft has a flat spot from wear. Check that out the best you can when you tear it down. If it is worn, take back the kit and get a new or junkyard box.
My truck leaks in the same spot as your bros except I can keep it from leaking if I park the truck with the wheels strait....
tmaxxman
PA
2.9L
i will tell him to check that out thanks for the info but his seal was real bad
wizkid00104
13
West Newton/Penn Hills, PA
2.3L/5.4L
I just had my steering box out to replace it. You need a 1 5/16 socket to get the pitman arm off. This is really a job for a large impact wrench, either a strong 1/2" drive or a 3/4" drive. I also needed a large cheater bar to pull the pitman arm with a rented pitman arm puller, that sucker was on really tight! Make sure you put some anti-seize on the splines before reinstalling. Best of luck!
