Starter help
Pineywoods
Pineywoods of Texas
1997 Ranger
I have a 1996 Explorer 5.0 164 tooth flywheel m50r2 trans in 1997 ranger, does anyone know which starter to use? I'm near blind from reading but can't find the answer. Please help
Jbrown1238
6
Largo, Fl
306
None
I am no expert but I used a 1993 Mustang 5.0 starter on a 01 Explorer engine with a T5, 5 speed in a 1999 Ranger. This is with a 164 tooth flywheel from a 1993 5.0 Mustang.
ford_ranger12
5.8
5.0 T-5 uses a 157 tooth flywheel. Whatever year model F-150 came with a 4.2 v6 manual should work since they had the R2 trans.
Jbrown1238
6
Largo, Fl
306
None
Yep, you are correct, I went back and double checked. The M-6375-A302 flywheel I used was 157 tooth. Sorry for the incorrect info.
ford_ranger12
5.8
No prob at all, I just knew a 164 on a mustang sounded funny lol
2Krngr
Parts Hoarder
136
2000 Supercab
Stepside
5.0L GT40
You need to use this starter.
1999-2003 F150 I300 "Short Nose" Manual Starter (for 164 Tooth Flywheel)
Reason being is the auto 164t flexplate and the manual 157t manual flywheels take the long nose starter, if you use a starter meant for these it will contact the flywheel all the time.
The other option is to get a starter spacer/adapter, which you can find on ebay, and the spaces the "long nose" starter out some and matches up the holes for a bolt on solution to use a starter you already have.
The expensive route is to get something like a B&M 77101 mini starter, these are like $250 though. https://www.summitracing.com/parts/bmm-77101/overview/
Pineywoods
Pineywoods of Texas
1997 Ranger
Thanks for the help. I went to Orielys and came away talking to myself.
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
any starter from a 88-96 f150 with the 4.9. 5.0. will work.
17,926
SW Iowa
Elutheros
129
Central Texas
O'Reilly part number: USL 32286 F150 V8 5.0 been working fine for a couple years in mine. I never counted the teeth on my flywheel but it came out of a 1994 F-150 5.0.
Pineywoods
Pineywoods of Texas
1997 Ranger
Don't know if i have the wrong plate or what, the starter lacks .001" of fitting the plate. I was hesitant to grind on it but don't want to chaneg the plate.
2Krngr
Parts Hoarder
136
2000 Supercab
Stepside
5.0L GT40
Did you get this fixed?
.001 is so minimal it must be the right plate, it seems a little grind, a little tapa tap tap, or adjustment of the plate would make it fit.
At first I would would think you were using a 157tooth block plate, but it would be 3/8"-1/2" off, so at .001 that's not the case.
mikesfiero
Not sure if this will help but I put in a 1996 Explorer in my Ranger mated to a T5 with 157t flywheel. I just used the original Explorer starter. I like it because it's small and seems to be powerful. I've been using the same starter for 4yrs now. I'm in Canada and drive my truck year round. Starts great in -30deg C weather.
Pineywoods
Pineywoods of Texas
1997 Ranger
I had the wrong plate, I found a bulliten from a starter manufacturer that gave dimensions. I tried to put it in tech articles don't know where it went. I ordered another plate from Bronco parts in Oregon and got it installed. Hey I needed the pratiice pulling my engine...
