Spring Insulators. Bump Stops.
High Desert Ranger
High Desert, Calif
I order a set of 4" lift Skyjacker springs for the front of my 1987 Ranger 4x4. I noticed that there seems to be a spring insulator at the bottom mount that is in sad shape on both side. Any ideas for replacement.
Also I will be extended my stock bump stops to prevent coil damage from happening again. I have 4" Rough Country Lift, should I use 4" bump stop exntensions or perhap 3.5" ones? What do you all use for bump stop extensions?
JohnnyU
"Outlaw"
8
Chillicothe, Illinois
Chevrolet
Ls2
The bumpstop should be positioned by cycling the suspension and looking for binding. I think I found the point at which the shafts started to bind and added around 1-1.5" to the measurement. The added amount should help counteract the compression of the bumpstop, that can vary depending on the type of bumpstop you use though.
samsonitesamsonite
Bellingham, Wa
Jeep
2.5
i have a piece of 2" square tubing to extend mine, you can buy extended stops but mine work just fine how i have it.
High Desert Ranger
High Desert, Calif
How about the spring insulators at the bottom of the spring next to the axle?
