bhgl
- Feb 28, 2024
- Reaction score
- 212
- Location
- Northern Ontario, Canada
- Make / Model
- Mazda B3000
- Engine Type
- 3.0 V6
- Automatic
- 2WD / 4WD
- 2WD
I know older rangers used a wyrm gear setup, newer ones used the ABS sensors, but there seems to be a weird gap from 2001-2003 in which they use a VSS sensor on the output shaft of the transmission.
I have forscan downloaded using the free extended license, I'm able to detect and open up the PCM, and GEM, but I have no idea what I'm looking at, nor what values if any ought to be changed, the speedo is not too far off since the tire's I went to are pretty similar in diameter. (well actually the needle itself is 20kph off but that's unrelated to values in the truck).
Any help as always is greatly appreciated, I can post pictures once I'm done work.
Thanks!
Thanks!
