JMF661
- Feb 6, 2020
- 120
- Montana
- Ford Ranger XLT
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 4WD
- Total Lift
- Stock
- Tire Size
- 31” x 10.5”
Hello folks,
I’ve got this old ‘94’s lift finished up (skyjacker 4” with radius arms.) I’ve got a little tire run that is occurring at full lock. Driver tire will rub on the radius arm when belting out a u-turn. Current solution is to simply stay away from full lock. However I am in the market for some wheels with a little less backspacing and some more negative offset.
I am currently running stock deer hooves 15x7s with 31 x 10.5 tires. I suppose I am interesting in hearing what some of you might be running on a similar set up.
I’ve been looking at a set of American racing AR62 outlaw IIs, that’s a 15x7 with 3.75 back spacing -6mm offset. This should set the wheel/tire about an inch away from the truck as stock.
I would definitely be interested in 33 x 10.5 tires! But I’m concerned even with a set of new wheels the radius arm rubbing would be the same or worse.
It is worth mentioning that I have removed the front sway bar and will not be using one in the future.
Anyhow, any wisdom or experience would be welcome!
Tires goes ‘round.
Tires goes ‘round.
