Sgt Ex
DC
6
Parkersburg WV
4.0 for now
stock
31s
if it aint broke dont fix it if it is broke upgrade
well brother, thank you from the very the bottom of my heart on what you are doing over there. Let me know if you need anything
I would also like to thank you for your services
I would love to have your advice when it comes time for me to build my explorer when i return home
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
When you return and start building, post up, we'd be glad to offer advice if/when you need it :icon_thumby:
SVT
Josh40601
MTOTM Winner
12
San Diego
SVT
Right here DC. Post a build thread when you start tearing into it. We will all help out
DC
6
Parkersburg WV
4.0 for now
stock
31s
I well an thank you both
Josh40601
MTOTM Winner
12
San Diego
Need some SME help. So after installing a new trans mount, the assembly still won't allow for full flat belly like before. The extrusions on the rear case are slightly touching the braces on the skid.
On my ranger, I ran solid mounts to the transmission and rear case and had poly bushings on the edges.
The biggest thing I'm worried about is cracking the rear housing case by sitting on the support. I can fix it after Harlan, but don't have time to do so before then.
Josh40601
MTOTM Winner
12
San Diego
well, those of my facebook friends have seen, the rear case housing busted. and I used RTV, duct tape, and zip ties to keep enough fluid in it I could wheel. Well, then I couldn't keep the truck in 4 low. the shifter kept popping out everytime there was any tension on it, so I finally just put my foot on it and floored it. Ended up running 1 trail completely, and ripping off a valve stem, then rolled my ankle.
So needless to say, this weekend at Harlan did not go as planned :/
Oh well. Got to see some good friends and drank enough for all the people who follow this thread, so it was all that bad. no pics except the duct taped case.
So now I will do some tweaks on it, as D-Ranged is nearing "completion". Hope to be able to wheel it again in January.
Seth, please post up those pics on how you adapted a 1354E case to work as a manual
Josh40601
MTOTM Winner
12
San Diego
No members online now.
