Rookie Needs help! Mystery issues '93 4.0
Spott
21
SE Idaho
No offense, but you need to start testing things instead of just guessing and replacing parts randomly.
8,372
Yes, I would agree, a $25 Volt/OHM Meter will save you Hundreds of dollars, literally, down the road.
modelageek
14
Boston, MA
Agreed, a MM is essential. You can get cheap ones at Harbor freight for $5 if you're totally broke.
Sent from my SM-J320V using Tapatalk
kpiztheniz
The battery was old as is. I have a MM....tell me what to test and what to look for. I agree, I'd much rather figure it out than keep guessing.
thanks!
modelageek
14
Boston, MA
I think Ron rattled off a test or two. I don't think the grounds/icm are your issue but you never know and it's basically a maintenance issue on your model. It sounds fuel related but the fuel seems fine.
You can buy a fuel pressure tester for $20. It only takes a few minutes to test.
2ndSS
10
Illinois
31" on the 02 FX4
kpiztheniz
did you get your truck figured out? give us an update
