roof poping
necessaryevil
salem,or.
2.9
at about 45mph my roof on my b2 pops, when i slow down it pops back, is there any way to stop this?
17,928
SW Iowa
Don't go above 45mph... :yahoo:
In order to make it stop you are going to have to find out what is doing it. Anything up there like a roof rack that might be loose?
master hec0
5
okotoks alberta canada
4.0L V6
sounds like the wind speed is causing it to push down and then when you slow down the wind dies down and it pops back up
Deamers87ford
Lancaster, Pa
weld some bracing on the roof?
bugflector II and a visor.
maybe.
martin
26
St Bruno, Quebec
1991
Ihere's a brace across the roof just behind the doors. What usually happens is something has been on the roof and bent the brace down. It was originally glued to the roof but has now seperated. If you pull down the roof liner you will be able to see if it's bent or just seperated. If it's bent you can just jack it back into shape and then re-glue it with something like construction adhesive or if it's not bent just re-glue it, Had the same problem with mine when I bought it many moons ago.
Tony Raine
17
Jonesboro, AR
302
+2 mine had the same problem
4.0B2
151
Walls, MS
4.0 v6
agreed.. had the same thing happen to mine. all i did was i had all my interior out for paint so i used a porta power and some portapoxy, reglued it to the roof. another thing you might look at while you do this is the joints in the corners when you have the headliner down. Alot of B2's have issues with where the side meets the top on the inside, the welds break loose.
necessaryevil
salem,or.
2.9
-REP UP-
pulled the headliner and sure enough thats what it was, a little bit of expanding foam-in-a-can and problem solved. THANKS GUYS!!
