RockRangerII refresh
RockRanger
7
Fresno CA
About a month ago I picked up a new to me used rear axle for the ranger. It is a disc brake explorer 8.8 with 4.88 gears an ARB locker and a C-Clip eliminator kit installed. Also included was a Ridler diff cover for the 8.8 and a one for a dana 44. I also got an ARB compressor and a YJ rear driveline for a friend for $650. I can't get just the ARB for that price.
So out came the old drum brake explorer axle with welded spider gears and 4.88 gears.
20170522_124156 by Matthew Dresselhaus, on Flickr
Next I cut some spring perches and an axle side traction bar mount.
20170523_105257 by Matthew Dresselhaus, on Flickr
20170523_111632 by Matthew Dresselhaus, on Flickr
I started installing the spring perches and traction bar mount.
20170523_113022 by Matthew Dresselhaus, on Flickr
20170523_113043 by Matthew Dresselhaus, on Flickr
20170523_113032 by Matthew Dresselhaus, on Flickr
20170523_192349 by Matthew Dresselhaus, on Flickr
20170523_192401 by Matthew Dresselhaus, on Flickr
Then the 8.8 has a nice lip on the bottom.
20170523_164436 by Matthew Dresselhaus, on Flickr
I cut plates and smoothed my last one and liked it so I am doing it to this one as well. Here are the plates.
20170523_154308 by Matthew Dresselhaus, on Flickr
The start of the install.
20170523_165636 by Matthew Dresselhaus, on Flickr
Grunizzle
01/2013 OTOTM Winner
Albuquerque, NM
4.0L V-6
Dude you stole that for$650
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Lookin good bud ?
Sent from my SM-G930V using Tapatalk
PlumCrazy
2014 Truck of The Year
177
Millersport, OH
Solid Axle Swap 4x4
Smoothing the lip on the 8.8 makes a night and day difference in rocks. That's most of the reason I narrowed a Lightning 8.8 for my rig. It has ribs in the casting that I tapered down to make ramps up to the lip.
Sent from my XT1650 using Tapatalk
RockRanger
7
Fresno CA
On the leaf spring perches I drilled a taped a hole to hold the explorer hard brake lines. The hole ended up a little high. On the next set if I do them again I have already adjusted the hole 7/16" lower to make the brake lines fit better The axle was missing all the e brake hardware so a run to the junkyard and a few orders to Amazon and I am slowly working on getting the ebrake sorted out.
20170524_113632 by Matthew Dresselhaus, on Flickr
20170524_115525 by Matthew Dresselhaus, on Flickr
RockRanger
7
Fresno CA
Still don't have the ebrake functioning as well as I would like. That didn't stop me from going to Moonlight Madness to play. The view off the tower on Bald Mountain was awesome.
IMG_0817 by Matthew Dresselhaus, on Flickr
Playing on bumper buster I just about maxed the front suspension. I have the bumpstops, and shocks set just about perfect.
IMG_0851 by Matthew Dresselhaus, on Flickr
IMG_0852 by Matthew Dresselhaus, on Flickr
IMG_0835 by Matthew Dresselhaus, on Flickr
IMG_0837 by Matthew Dresselhaus, on Flickr
Then a quick video I made of a few of the obstacles we played on.
https://www.youtube.com/watch?v=DUDrAL3R7EI
Grunizzle
Albuquerque, NM
4.0L V-6
as usual, looking awesome
RockRanger
7
Fresno CA
I was replacing a worn out TRE on the front end when I happened to look at the axle side trackbar mount and saw this.
20170703_140024 by Matthew Dresselhaus, on Flickr
That bracket is about 6 years old with about 10k miles on it. It is the only bought bracket I have used on the truck. So I started designing up a new bracket to replace the failing one.
bracket2 by Matthew Dresselhaus, on Flickr
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Is that a rough stuff bracket? Your design looks good but that thing will fill up with dirt quick.
RockRanger
7
Fresno CA
Yes it is. I noticed the one they sell now has been redesigned. The bottom has holes in it so any mud can be washed away. It has bigger drain holes then the ruff stuff one did and there was no noticeable mud caked it the old bracket.
Sent from my SM-G920V using Tapatalk
Rowdy Fitzgerald
Hog hunter
Firefighter
EMT / Paramedic
372
Nevada
5.0,4.0
Solid Axle Swap 4x4
6”
Oh ok.
mavereq
Concrete, WA
That's fixable
RockRanger
7
Fresno CA
I fixed it by cutting it off and building a new bracket.
mavereq
Concrete, WA
That looks stout
