Replacing the insturment cluster on a 2007 Ranger
rdsrds123
2.3
Hello, I need to replace the instrument cluster on my 2007 Ranger. It has a tach.
I contacted a place called the instrument cluster store and they have one. However, they say that it is not a simple plug in procedure, and that it needs to go to a dealer to do this. Is this so, and is there some way around this? thanks!
8,372
No, no way around it.
2004 and up used digital instrument cluster that is part of the PATS(passive anti-theft system).
The computer that runs the engine will not turn on fuel pump or fuel injectors if key or instrument cluster do not "check out"
Starter Motor is also disabled but that can be "fixed", but no way around no fuel
Cluster has a digital signature that was programmed into the computer when vehicle was assembled, new clusters signature needs to be added to computer, and thats a dealer thing.
You can drive it to the dealer swap dashes, then let them reprogram it, then reassemble everything at home.
BUT..................digital odometer can be an issue, check with the dealer, they may say NO.
Installing a used cluster with LESS miles is illegal, not sure about MORE miles.
Ford dealers order replacement clusters with vehicles miles preprogrammed, not even dealers can do "roll backs" or adjust digital odometers.
rdsrds123
2.3
Wsljr2208
My ranger is an 04 im not sure about having to reprogram the comp to talk to the cluster but i do know that the mileage comes from the ecu not the digital odometer so if its used as far as milage goes doesnt matter
Sent from my SM-J700T using Tapatalk
