mountainkowboy
- Dec 15, 2007
- Reaction score
- 0
- Age
- 66
- Location
- Socal Desert
- Make / Model
- Ford
- Engine Size
- 3.0
- Manual
- My credo
- Sucks to be you
My 2011 sits warnkie in the back and I've narrowed it down to the springs. Its 1" lower on the RR and the measured spring length is different from side to side, so I guess my springs are worn out, or at least the right one is. It also doesn't really sit higher in the rear as it should. So long story short I'm going to replace the rear springs as a set and I'm looking at these https://www.generalspringkc.com/product_p/43-1503hd.htm .
They have a higher weight rating than the stock 4 leafs...would these be for the longbed? Either way I think I will go with them since it will be towed behind a MH with a Harley in the bed, and I will add stable loads to it also. Probably won't ride real well unloaded, but it is a truck....
