Rear End Flange wobble
FTSK95
FORD
2.3L
The flange on my 7.5 rear end is wobbly. I've noticed a vibration from the driveshaft at highway speeds. So i crawled under the truck and found I could wiggle the flange that comes off the rear end up and down. What can I do to fix this problem? The truck drives fine, it's only when I'm slightly on the gas I get a vibration. Any ideas? :dunno:
martin
26
St Bruno, Quebec
1991
sounds like pinion bearings.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yup, you've got loose pinion bearings.
FTSK95
FORD
2.3L
crap...what can I do to remedy this? I recently had gears installed (about Sept. 08') Do I need new bearings? Or would I be able to tighten the pinion nut? Any input would be appreciated, thanks!
4x4junkie
585
So. Calif (SFV)
2.9L V6
35x12.50R15
Sounds like somebody reused the old pinion nut without putting Loctite on it.
I'd take it back to whoever did the gears and hope there's no damage inside there.
FTSK95
FORD
2.3L
Double crap....thanks for the info! I obviously shouldn't drive it then huh? This SUCKS!
4x4junkie
585
So. Calif (SFV)
2.9L V6
35x12.50R15
I definitely wouldn't.
