rear drive shaft
tomisb
grants pass oregon
2.9L
How much lift can i have before i need to modify the rear driveshaft? Ive got the stock toulip style cv shaft and im planning on modding a explorer shaft to fit but thats after the lift.
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
how much are you planning on lifting it?
tomisb
grants pass oregon
2.9L
I havent decided yet. Im peicing together my SAS right now and i just was curious if i lifted it X amount i would need a different shaft. Im planning on using lifted YJ leafs up front and i already have comanche main leaft out back and its sitting level now. I might even inboard the rear leafs so they are under the frame like a YJ. And that will net me more height with the springs i have now.
Surrey
10
Vancouver, Canada
2.9
Well the CV shaft will get you 2-3 inches, at best.
tomisb
grants pass oregon
2.9L
Thats what i figured. Thanks.
4.0B2
151
Walls, MS
4.0 v6
get rid of the cv now.. or it'll die and leave you stranded. i drove home w/ FWD only 2wice b/c of it...
tomisb
grants pass oregon
2.9L
My plan is to get a couple exploder drive shafts and piece together a good rear shaft. Any perticular modle or year i should look for?
--weezl--
Law Enforcement
182
hell
you should be able to get more than 2 inches out of a cv driveshaft... your standard cv axle shaft (diff to hub) can go about 2" extra, and your driveshafts are much longer, so the same lift, will increase the angle of the joint by less than that of the same number of inches on a shorter shaft (axle shaft)
like everyone else has said, it's a crap shaft, but 2-3 inches of lift, i wouldn't worry about it immediately... just keep checking for play in it, it SHOULDN'T fail without warning... if play is noted, make sure you get a new shaft on the double
Surrey
10
Vancouver, Canada
2.9
Hes talking about a SAS swap and shit... No way hes only doing 3" of lift.
For his application, it is clearly in need of replacement.
4.0B2
151
Walls, MS
4.0 v6
yeah i knew mine had like an 1/2th of an inch of play in it.. should have changed it immediately
my shaft is a 93 4x4 ex's shortened w/ 2 front flanges on it.. that way it bolts to the 7.5
honestly if you got the dime i'm thinking tom woods custom.
--weezl--
Law Enforcement
182
hell
good call surrey...
even still, i personally would chance it, and just check every week or so, for play, as long as it's not binding up, at full droop, it shouldn't have spontaneous failure... but danger is my middle name...
that being said, regardless of your shaft, you should be checking your u-joints for play before taking ANY wheeling trip, or long road trips, along with checking tires for abnormal wear/cuts in the sidewall, all of your balljoints and tie rod ends, pitman arms, radius arms, shocks, and all of your applicable fluid levels... though it's much easier said than done... last time i checked my front diff was when i changed the fluid... lol
Surrey
10
Vancouver, Canada
2.9
good call surrey...
This sounds like someone who hasn't experienced the misery that is the CV shaft...
Plus when you blow that, you are now relying on a d28 to get you home. (I guess not in the case, 'cause hes doing a SAS, but for others...)
tomisb
grants pass oregon
2.9L
So will any explorer rear shaft work if I shorten it and put front flanges on it
--weezl--
Law Enforcement
182
hell
honestly, surrey, as long as you check it, you shouldn't ever be stuck in that situation... regardless, it should be a u-joint shaft, as soon as possible, but if money is tight, the cv will work for now...
you could shorten it and put a ujoint flange on, but i would just go get one the right length from a jy, it will probably be cheaper than getting an old one re-worked to be what you want it to be
Surrey
10
Vancouver, Canada
2.9
Well I am going to temporarily run the cv driveshaft in a week when my 4" coils show up. I will let you know if I blows up before I can replace it...if it doesn't, I will probably hold onto it for spare parts, for when I bend the other one on a big rock...
