the frame was actually not too much of an issue-most of the problems in that area come from the many changes over the years that left holes drilled for brackets,weld stubs left after things had been cut off,etc.the frame i'm using now will be reinforced using the knowledge gained from the previous one,but while i thought of fabbing up a new frame from box tube,i have an insane need to keep at least some of the frame of the original vehicle intact(for another example of this see my thread 'gt12'-that would also be easier to start from scratch)
only the rails were kept,all crossmembers were fabbed and the cage added the needed stiffness-there was no flex in the frame at all.
you will note that i am speaking in past tense,the truck as seen in this thread has already been torn down,and the new one is a rolling chassis with most components fitted.as stated before,a build thread will be put up that starts from the day i bought the original truck-a 4cyl 2wd that was purchased specifically to build up,though i never thought it would end up like this.
and as josh has stated,i'm spending too much time on the 'little rocket ship' to do this one justice right now.
