Ranger body to Mounty frame swap?
Ruffinit
Muscatine, Iowa
4.0, 2.3 Duratec
So... I'm going to start with Mountaineer and Explorer frames of like years being the same as a statement.
I'm sure someone here has taken a body off of an Explorer/Mountaineer. I have a 2000 Merc and am now considering moving my Ranger cab / bed to this frame. I've figured out that the wheelbase is the same (111.6), but don't know the track comparatively. I also don't know how the frames actually compare. Has anyone done this or have pics of the frame(s).
alaskan155
6
washington
FORD
7.3l/4.0l
Ruffinit
Muscatine, Iowa
4.0, 2.3 Duratec
Alaskan - Thanks. So I take it the top frame in the photo is the Ranger and the bottom would be the Explorer. So what you're saying is that the cab will mount right on the Exp frame with the shared mounts but I'd have to create body mounts for the bed at the right height? I wouldn't think that the spring-under-frame would be a big deal. I want the ride height low so as not to advertise the AWD or change the suspension characteristics much. I don't haul with the Ranger, but I do tow and I already have rigs I can 4 wheel with. Am I reading that right?
Oh and thanks for that link. It's EXACTLY what I was looking for.. this is gonna be fun as my little Ranger's a single cab stepside, so it fits the wheelbase.
17,867
SW Iowa
Where it becomes kind of a big deal is that the springs are mounted the same distance apart between the ex and the Ranger... so for one to be under the frame (Explorer) and one to have the springs mounted beside the frame (Ranger) it means that the frame is that much wider.
If I read it right the rear cab mounts (one pair under the front seats and one pair under the cab corners on an extended cab) won't line up with the Explorer body mounts.
alaskan155
6
washington
FORD
7.3l/4.0l
there are 6 body mounts on the cab, the front 4 will line up that is it, and that if you are running a 98+ ranger radiator support. if your ranger is older than 97, only the 2 middle mounts on the cab will line up. (behind the front tire)
so on a 98+ cab, you will have to fab up the 2 rear mounts and all the bed mounts.
will need the photobucket plugin to view photos but here is another
http://www.therangerstation.com/forums/showthread.php?t=3497
the 91 to 94 explorer frame body mounts are the same as the 95-01 minus the front radiator support mounts.
Ruffinit
Muscatine, Iowa
4.0, 2.3 Duratec
The second link was entertaining enough, but the first link had a lot of good information. I'm going to possibly have to pull the radiator core support out of the Mounty, fab rear cab supports and bed supports. The only real challenge may be the fuel filler tube. That may even be a non-problem if I use the fuel tank from the Ranger. Both the Ranger and the Mounty are fully functional at this point, so the nice thing about it is that before I begin I know that everything works. I may have to build upper mounts for rear shocks, but that will be something to keep in mind. My neighbor is a welder by trade and his son is also certified so I'm going to pass this by them. I live in the boonies so there are only 4 houses within a few miles. I'm thinking this is doable.
