Antonio quinto
- Feb 10, 2009
- 0
- ranger 88
Hola:
Tengo una falla en una RAnger 88 motor 2.9, la falla es la siguiente:
de repente pierde potencia y a los tres o cuatro segundos se recupera, he probado cambiando las dos bombas de gasolina, pero el fallo continua, he sacado los codigos de error y son los siguientes, con motor apagado 67; 12; 94; 19; 62; y con motor encendido son 12; 21; 13, 77;
hi:
i have a ranger 88 2.9L and it falls, when is hot loss power for 3 or 4 seconds, and rerecover de power, i tray with a new fuels pumps, one at the frame rail and other at fuel tank, are new, a have test the truck whit a fuel pressure test at de windsheld and the fuel pressure normal is at 30 lb and whel fails is at increse to 40lbs, an i was intent to fix the problenm with a new tfi module, but does not work, the trouble codes are engine off and sctch on: 67; 12; 94; 19; 62; an engine run 12; 21; 13, 77;
what can i do?
hi:
what can i do?
