Ranger 4x4 coils.
lethal-threat-b288
39
plant city, fl
5.8,2.9,2.3
are the 4x4 ranger coils the same length as the 2wd rangers?:icon_confused:
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Coils & leafs are the same. Difference is the 2WD does not have a rear block, and the 2WD I-beam is shaped different.
lethal-threat-b288
39
plant city, fl
5.8,2.9,2.3
Then how is the sploder any diffrent? I heard the sploder springs are longer.
Original_Ranger84
20
2.8L, 3.0L
Explorer leafs are heavier duty and will not bend as much thus giving you a little more lift and load capabilities but I have explorer springs in my ranger and they weren't any longer.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Explorers also use a spring-under-axle configuration. Because of this the leafs are arched a slight bit more as well.
lethal-threat-b288
39
plant city, fl
5.8,2.9,2.3
I knew that, I'm just Lookin at some 4x4 coils. I have a 2wd extcab 2.3 and he has a 4x4 4.0 ext cab
Original_Ranger84
20
2.8L, 3.0L
The springs should all be the same size but the load ratings on them will be different, a 2wd will most certainly have softer coils then a 4x4.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
I think it depends more on optioning, such as engine size and Supercab/Std cab.
A 4.0L Supercab truck w/AC will have heavier springs than a std cab 4-cyl, regardless of which one's 2WD and 4x4.
But the springs will still physically interchange however.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Those links don't work if you're not logged into that site.
My '94 Ranger springs were less-arched than a set of junkyard Ex springs I had bought ('00 IIRC). Maybe it must vary between models then.
brinker88
11/2013 OTOM Winner
36
Williamsport, Pa
Shit...that's my supplier for my shop...I'll have to print them out at work and take a photo of them. Gives you all the springs ford ever used in the ranger/expo with bushing sizes/part #s, arch, lengths, etc.
Boggin
48
I was told on BroncoII.org that 2wd ranger coils will give you maybe an inch or 1.5" over stock 4x4 coils. not sure if thats true or not. i might try it, since i have a 2wd ranger and my b2 in the garage now at the same time. ill let you all know how it works out.
