Radius Arms and Air Intake
svo_jon
Bend Oregon
Is there such a thing as an affordable set of extended radius arms?
And dose anyone make an air intake for a first gen explorer?
Thanks
Jonathan
rngmStr
Pacific NWest
Xplorer
HOMEBREW extended radius arms - KKM/HOMEBREW open air intake?
Beanmachine7000
5
Tennessee
Thanks
Jonathan
Did your truck not come with an air intake?
svo_jon
Bend Oregon
WOW... really?
OK Mr. smart, an after market performance air intake.
I am just looking for any ideas to improve the performance/effisency of my EX
sorry if you were being serious.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
If you do a search, you'll find many MANY threads about intakes. The general consenus is that aftermarket intakes do not help performance at all. Nobody makes an intake for a 1st-gen Explorer that I'm aware of anyway. Save your money and keep the stock intake.
BlackBII
Ranger Custom
Truck of Month
982
UT
Junk Collector
Truck of Month
4,836
Rapid City SD
WOW... really?
Nothing you can bolt on before the intake besides a turbo or supercharger is going to have any measurable effect on anything. It's a waste of time and using things like oiled K&N filters can actually hurt engine performance because the oil contaminates the mass air flow sensor.
Beanmachine7000
5
Tennessee
WOW... really?
I was assuming you would not want to remove the factory COLD air intake, so I figured it just didn't have one...
The factory position and routing of the intake ducting makes it a true cold air intake, as opposed to the K&N and other aftermarket setups which just have a conical filter open to the engine bay allowing it to suck up the HOT air in the engine bay, along with the aforementioned MAF contamination. There was a dyno sheet posted here somewhere a while back that showed with just a K&N CAI system a 4.0 Ranger LOST performance, about 20 HP worth. Leave your intake alone.
As for affordable radius arms, well I guess that depends on your definition of "affordable".
Browse through the For Sale section here on TRS and look through your local CraigsList. Maybe you will find a used set cheap. I've seen a few complete 6" suspension lifts, extended arms and all, go for under $300 here.
svo_jon
Bend Oregon
Thanks for the thoughts on the intake.
I think after reading the tread on the Radius arms I will build my own.
Thanks
Jonathan
gribly
28
Maine
Honda
K20A3
Sounds like you are off-roading your X. In that case, cut the factory cold air intake off, and if you live where they don't check, take the warm air tube and valve off as well and cap off the vacuum ports for it. The factory intake sucks water in. Your other option is to cut a hole in the passenger side fender and run a snorkel. I honestly wouldn't do anything else to that motor besides water-proofing.
Gribly has a point. If you plan on doing any serious off roading a snorkel is your best bet. The factory intake is at roughly the mid-line of the grille. That means it will suck up water if you get into anything deep.
svo_jon
Bend Oregon
Thanks, but I live in the high desert...so deep water crossings are a big deal. Now fine dust is a big problem.
Well then I wouldn't worry about sucking up water.
As for fine dust, stick with a paper air filter. I recommend Motorcraft or Fram. I will knock Fram any chance I can find, but even I will admit that they make a good air filter.
I've seen their oil filters destroy engines by sucking so bad. Their air filters are pretty good.
I'd stick with a Motorcraft FL-1-A oil filter. They are high quality, catch most fine particles that find their way into the oil, and usually cost the same as or less than aftermarket competitors.
