Radiator upgrade
bfiakas
Gilbert AZ
2.9l
I want to upgrade to a larger radiator in my 88 Bronco2 W/manual transmision.if I install a 2 core radiator from the stock 1 core, does it change the air draw through the fan shroud and what radiator should I use?
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Just get a radiator and shroud from an Explorer.
The Mud Addict
15
Roy, WA
'85
2.8 V6
2.8 D-S
6in
35x12.5x15 Pitbull rockers
Pre '94 Exploder:icon_thumby:
17,884
SW Iowa
Pre '95, 91-94 is the same. Has to be from one with A/C and an automatic transmission otherwise it will be the same as what is already there.
unoleisu
6
Stillwater, Okla
2.9
I did this upgrade myself. I have an 87 BII (2.9, M5OD) that was originally automatic, and used a new radiator for a 94 Exlporer. It was an easy swap. Under normal driving conditions, it cools too much. I have to block off over half of it.
Even with 100+ degree weather for over 50 days, the only time my engine got up to normal temp. was when I took a 3.5 hour road trip at 65 miles an hour, in 105 deg. weather. Now that the temp outside is between 35 deg, to 70 deg., it never gets above 180 degrees, verified with a thermometer.
I noticed my mileage went down, I believe because the engine is running cooler and the computer is running the fuel richer. I read theories that this would produce more power, but I didn't notice any real difference.
bfiakas
Gilbert AZ
2.9l
Thanks for great real time info ,that's was my other queston is over cooling.I have the stock T-stat 192 degs in there and I want stay with that.I am planning to pull a 1000 LBS travel trailer.
bfiakas
Gilbert AZ
2.9l
Thanks to everyone for the good info
17,884
SW Iowa
I have heard that too with stock V6's, it works great for my 302 though :D
