Pulling fault codes
MordacP
Where is the self test connector on the 1990 ranger 2.9? Pictures would be appreciated.
BlackBII
Ranger Custom
Truck of Month
982
UT
Check the passenger side, under the hood, behind/below the power ditribution fuse box.
gatorman
see link
PHP:
http://www.therangerstation.com/tech_library/diagrams/4hup96.gif
It in on the right side (passenger) between the side and air filter. There are two pieces. On mine, the big one is red, the small single is gray.
JimG
West Tenn
xlt 4x4 2.9
Thank you gatorman,,,,, I had looked for an hour and a half. It was disconnected from its mount and hiding under the fuel pump relay.
I almost lost my mind.
45-70
12
Sweden
Ranger STX
29"
What do you use to red them? I suppose it’s not a standard OBD?
8,370
1983 to 2011 Rangers used two different OBD(on board diagnostics), OBD-1 thru 1994, and then OBD-2 starting in 1995
OBD 2 was required in ALL vehicles sold in the US/Canada in 1996 model year and up, and still used today
Yes, you need an OBD1 reader for 1994 and earlier, OR................you can use a test light or volt meter to read "pulses" from the computer to get the 2 digit or 3 digit Codes, this doesn't work for OBD2, only OBD1
45-70
12
Sweden
Ranger STX
29"
Cool! But it semes hard to find a fair price obd1-reader where I live. There are adapters for obd2, which I already have. Does that work ok? I get the impression Ford has their own standards when I google.
8,370
OBD1 tended to be Car Maker specific, OBD2 has generic codes that all car makers were required to use, but there are car maker specific codes in OBD2 as well, P0xxx is generic, P1xxx is car maker specific
No adapter, best to just count the pulses to get the codes for free on OBD1
Go here: https://www.therangerstation.com/tech_library/index-charging-ignition.shtml
Look at EEC-IV diagnostics fist
There are also the Ford code lists, 2 and 3 digit, which is year specific
franklin2
1,758
Virginia
Here's another link on code reading. Just use a testlight, you should have one in your toolbox. Go buy one if you don't, you need it for other things and you should learn how to use it.
45-70
12
Sweden
Ranger STX
29"
