- Mar 24, 2013
- 9
- Age
- 80
- Renton, WA
- 02 2X4; 08 FX4
- Ford
- Engine Size
- 4.0 SOHC
Yep, cheap engine on CL = core!!
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Thanks.Check for a ridge on the cylinder walls and get the heads magnafluxed. Was it getting good oil pressure? Can you still see crosshatching on the cylinder walls? I would just get the valves ground and new guide seals and put it back together. Be sure and put a bead of permatex in the valleys between the heads and block when you put the intake back on. Do not use silicone anywhere on the engine.
