Powertrax Lock-Rite in 7.5"
colinrmitchell
Feels good, man.
4
Copley, Ohio.
2.3L
I've seen that it said that the Lock-Rite can only be used in carriers with 4.10:1 and up. Why is this? Is it for clearing the crosspin past the ring gear, or other reasons?
See, I got one in my 7.5" with 3.73:1s, and I'll be wanting to eventually regear to 4.56:1, so is this gonna be a major problem? Or can a grind the pin and/or gear teeth to get the pin out when the time comes?
Thanks,
Colin.
Ranger44
23
Illinois
FORD
4.0 OHV
I think it is a crosspin clearence issue. All that is needed is a little grinding of the ring gear.
I've heard people have had the same issues even with stock 4.10's.
edit: what size of tire are you running?
colinrmitchell
Feels good, man.
4
Copley, Ohio.
2.3L
I'll be running 33x12.50 TSLs.
The 3.73s now have no nuts on the road (relatively: 33s + 2.3L = slow). Just checking, I figured it was cross pin clearance.
Ranger44
23
Illinois
FORD
4.0 OHV
Cool....thanks.
I've got a 2.3 4x4.....
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Yep I had to grind the ring gear a bit to get my cross-pin out of my 7.5 with 4.10s, 3.73s also need to be ground as well. A notched crosspin wont work with the locker and it's weaker than a full pin anyways.
