Positraction Limited Slip
professor229
77
Minnesota
Just a quick question.... I don't know if my project 2004 Ranger has positraction (limited slip; whatever) and I am just curious. I read another entry where the guy said he looked on the door jamb I believe for the axle on a listing of some kind... Is there a way to find out if your Ranger has limited slip by decoding something or looking at a listing somewhere? I thought my Chevy W/T had posi.... thought all work trucks had posi.... I was wrong.... but I would like to know if the Ranger has it or not.... Thanks
rusty ol ranger
2.9 Mafia-Don
7,688
Michigan
177 CID
If you have a letter in the axle code along with a number (IE D9) its limited slip.
You can also jack the ass end up and spin one tire by hand and see if they both spin the same direction
alwaysFlOoReD
5,135
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Also there is a tag on the back axle showing the gear ratios. Eg; 3 73 xxxx xxx
If its a limited slip it will have an "L" after the first number.
Eg; 3L 73 xxxx xxx
19Walt93
4,500
Canaan,NH
351
3"
235/55R16
No Ford vehicle ever had positraction, that's GM trade name for limited slip. A posi is what the high horsepower GM guys remove after it grenades a few times so they can install a Ford Traction Lok rear end. Some of my commercial snow plowing customers would refuse to buy limited slip because it can cause the truck to slide sideways if it starts spinning and that can cause damage if it slides into a house or garage when they are plowing.
Roert42
5,031
Kintersville, PA
Ranger XLT
4.0 SOHC
Ford doesn't even offer a limited slip as an option any more. You get an electric locker or you buy something with AWD.
Even if your truck came with one from the factory, it's likely that it's worn out by now.
8,374
Go here: https://www.therangerstation.com/tech_library/axle_codes.shtml
That will show you what to look for
Yes, GM called their limited slip posi-traction, Ford called theirs Traction-Loc
Both use Clutch packs in the differential to balance torque on the 2 axles
If one axle starts to spin faster than the other axle then less torque is sent to that axle, giving more torque to the slower spinning axle
So if a wheel starts to spin on a slippery surface the other wheel(thats not spinning) gets more power to move vehicle forward(or backwards)
Traction-loc sends torque/power to the wheel with the best traction
A regular differential is called an OPEN type, it sends all torque(power) to the faster spinning axle, which is why only one wheel spins on a slippery surface, applies to rear wheel drive or front wheel drive
A full Locked differential means both axles HAVE TO turn at the same speed, they are in essence one axle with 2 wheels
Anytime you go around a corner the outer wheel must spin faster than the inner wheel because it is traveling farther
And that's why its called "limited slip", these types of differentials allow "limited" difference in axle speeds, they allow the outside axle/wheel to "slip" a bit so it can spin a bit faster than inner wheel
An OPEN differential doesn't have an issue with turning which is why its used on almost all vehicles
A full Lock differential is great for driving straight, but when you turn one wheel MUST be dragged so its not turning any faster than inner axle/wheel, very hard on the tires, lol
Full lock is usually only used off-road where a tire can be dragged easily on non-paved surfaces
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
I don't know Walt...this guy does seem to be a case where a factors limited slip will work ok...based on info given...
But...calling these good...nah.
Traction locks are for people that don't need actual traction....just some help...
On flat ground...in perfect conditions.
Both of these, gm and Ford are garbage if you need traction to get somewhere reliably.
....I have blown way too many too hell...because cheap alternatives were not easily available at the time.
Blowing spiders through the cover or case after trying to make these failures work for high traction off road use left me hanging more then even transmission failures.
Low tire....will toast it...or in winter spin you out when you least expect it if it's fresh....odd size spare like many run....will smoke a new one in 20 miles.....just another open diff...
8,374
3 "L" 73 means 3.73 ratio with Limited Slip
3 " " 73 means 3.73 ratio but OPEN type
rusty ol ranger
2.9 Mafia-Don
7,688
Michigan
177 CID
This is all assuming the tag is even there anymore :)
professor229
77
Minnesota
I spent some time figuring it out and visiting the suggested linked websites to do some decoding and figuring out what I have... and as you might expect, I have a basic plain jane model which is fine.....The tag on the door jamb had the axle number 86 which decodes to
86open 7.5"27503.73
I was kind of hoping for limited slip but this is fine.....
I also tried to decode the VIN number and that was pretty accurate too but there was one letter that did not make sense and wasn't listed or I didn't copy the VIN right..... But the four position letter is Y and that is not listed....
4th Position (Gross Vehicle Weight Rating​
A – Up To 3,000 lbs.B – 3,001-4,000 lbs.
C – 4,001-5,000 lbs.D – 5,001-6,000 lbs.
E – 6,001-7,000 lbs.F – 7,001-8,000 lbs.
G – 8,001-8,500 lbs.H – 8,501-9,000 lbs.
J – 9,001-10,000 lbs. K – 10,001-14,000 lbs.
L – 14,001-16,000 lbs.M – 16,001-19,500 lbs.
I will need to venture out later and double check that fourth letter....
Overall though, I learned a lot.... have a good weekend!
8,374
pjtoledo
3,004
Toledo Ohio
Fords
3.0 2.3
from a 2005 manual. the link RonD posted has this and much more info.
70507
professor229
77
Minnesota
In other words, the website I was using to decode the information on the sticker was not complete.... I first thought I perhaps copied the information wrong.... that's been known to happen a lot more times lately...... but I double checked and I was right....I should have googled looking for another website to decode that information.... but the picture above says it all.... and thanks for that..... and it wasn't a big deal, but it is nice to know what you have bought.... Have a good one!
