**PLEASE HELP with stock rim vs. new tires**
SilverBlur4x4
Charlotte NC
FORD
I need some help from some experienced wheelers out there.
Ok, I have trying to figure this issue with my stock rims (15x7) and the installation of new tires and cannot come to a conclusion on my own so if anyone has some good sound advice please help me out here!!
I have a 2002 FX4 Offroad 4.0L truck and my stock rims are 15x7...I am going to put 3 inches of lift on my truck and I want to get 33x12.50/15 tires. Is 12.50 too wide for a 7" rim?! I am not going to by new rims because I truly like the stock ones. I have heard of many putting 33x12.50s on a 8" wide rim so I figure it's possible to put 12.50s on 7".
I even heard of a 4x4 magazine just recently putting a 13.50 on an 8" rim but just trying to clarify here...
I'm just not sure if I will have to run lower psi to keep from having a "balloned tire", or kill my tire mileage by doing this. Has anyone done this or know of someone that has? Were there any problems?
If you know how to answer my question, please go into full detail because I am strattling a fence on what to do here.
Thanks in advance,
- Riley -
86isuzu
TRS Member Since 2003
Firefighter
EMT / Paramedic
ASE Certified Tech
Ham Radio Operator
9
Eden, NY
Ford Bronco II
2.9L
2"
31"
i've got 11.5 on a 7 in rim. it should work. u plannin on wheelin?
BlackBII
Ranger Custom
Truck of Month
982
UT
It's possible to put a 12.50 tire on a 7" rim, but it's hardly recccomended....
8" - 10" is a better width to use so the side walls don't bulge horrifically and the tread wear is even...
rickcdewitt
5
nor-cal
4-0 swap
a 9" wide rim would be perfect but are hard to find
martin
26
St Bruno, Quebec
1991
A lot of the guys around here are running 33 x 12.50 on 7" rims, including myself. no weird wear issues.
LittleBigFoot
5
Denver Colorado
Mostly Ford.
Building a 408w
I'm runnin 15.5" on a 10" rim some how. Those tire boys at Wal Mart sure had to put some back into it tho.
Havn't had any problems yet....
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Go with 33x10.50-15 tires.
33x12.50 is too wide for a 7" rim, they will not wear properly (and yes, lowering the pressure will kill your mileage)
AngloSaxon
Charlotte, NC
2.3
Speaking of 33x10.50r15's, is BFgoodrich the only manufacturer of all-terrain tire that size?
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,855
Pittsburgh, PA
2.3 EcoBoost
1.5"
I think Pro Comp also makes a 33x10.50 A/T but I'm not positive. 7" is really too narrow, also the stock rims have too much backspace for a 12.50 and they will probably rub on the inside. 15x8 with 3.75" backspace, steelies are reasonably cheap, and you're good to go.
86isuzu
Firefighter
EMT / Paramedic
ASE Certified Tech
Ham Radio Operator
9
Eden, NY
Ford Bronco II
2.9L
2"
31"
Mickey Thompson Desert Kings and Super Swamper Thornturds
