Photos of different wheel/tire sizes on stock and lowered 2WD's
justlexi
6
Florida
4x4 Wildtrak
What are your thoughts about Black Rhino truck wheels? I want to purchase a set of two-toned rims and have seen a lot of great designs from this brand. I wonder if the price is worth it for its quality.
keytimothy
Natalia, TX
Ford Ranger XLT
OK, I'll play. This is the low-buck edition. If you're looking for something radical, keep moving. :)
Drop: 2-1/2" rear w/ hanger flip, 2" front with Western Chassis coils
Wheels: '07 Mustang 16" X 7" Base Model
Tires: stock Mustang 215/65X16 BFG's - I plan on a set of 225/65X16 General Altimax HP's when the BFG's are done as the OD of these is nearly identical to the stock 225/70X15's.
Offset: 37 mm
Spacers: 1-1/4" cheapos rear, 1" Eibach front
thanks nice. I have been looking at mustang rims for my 92. Thanks for sharing.
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
what size and make are those tires and rims? 3/4 drop kit?
2020 Mustang wheels, 18”. 235/50-18
3/5 Drop..with 5/8” Poly spring isolator.
With 1.5” Wheel Spacers.
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
cschannuth
33
Hermann, MO
306
Expect nothing and I’m like really disappointed
‘83 on stock suspension but it sits a little lower with the 5.0 up front and 150 lbs of steel under the bed for traction. I also added anti-rollbars to the front and rear. Still has a nice soft ride but it corners flat as can be.
255/60 15’s on 15x8’s in back with 235/60 15’s on 15x7’s up front.
rangerguy98
I have a 98 2wd ford ranger and i have a set of track pack wheels off of my 2014 mustang the back fit fine could use some spacers to move the wheels out to fill the fenders out. But i cannot get the wheels to fit the front wont fit over the hub did you have to use the 1 1/2 spacers to get the front wheels to go on?
Rsd111
Manchester,Ky
18" x 8" Boyd Coddington Junkyard Dogs w/4.5" backspacing & 225/40R18 Hercules "Ironman" tires.
I'm using Chassis Tech 3" drop beams on the front & Competition Engineering ladder bars on the rear. It also has Slam HE-6 bags on the front & Airlift 2600 bags on the rear. We set the suspension up to match the 3/5 drop, beam/rear flip kit I originally had on the truck at full ride height.
Dose the rears clear pretty good?
insaneranger
42
Tennessee
302
225/40 R18
da-chief
9
Gadsden, AL
Ford Ranger Sp
Here is my 2000 2WD with the Jegs (looks like) Torq Thrust wheels. 225-70-15 tires.
61280
MrGearhead
16
Illinois
𝔽𝕠𝕣𝕕
𝟛.𝟘
‘83 on stock suspension but it sits a little lower with the 5.0 up front and 150 lbs of steel under the bed for traction. I also added anti-rollbars to the front and rear. Still has a nice soft ride but it corners flat as can be.View attachment 59153View attachment 59154 255/60 15’s on 15x8’s in back with 235/60 15’s on 15x7’s up front.
I’m thinking about getting those for my ‘06.. I’m 2WD . I don’t know the offset.
Where did you get them?
cschannuth
33
Hermann, MO
306
David’s Rally Wheels on line.
svtcards
137
Lyman maine
302
3'' front 4''back
