painting interior pieces
suzuki2903
ohio
what kind of paint are you guys using? i saw there is special spray pain for plastic but wonder what i should do to prep the plastic trim before painting? i dont think that soap and water willl remove armor all etc that could make the paint bubble
outlaw
EMT / Paramedic
27886 N.C
I used denatured alcohol and scuffed the panels and used regular paint
Timo99
Maury, NC
3.0 Vulcan V6
Krylon spray paint ftw.
nitrofan1
Man without a Ranger
MTOTM Winner
19
Chattanooga, Tennessee
Subaru
EJ251
On the surrounds for the door handles I cleaned them with dish washing liquid, lightly sanded them, 4 coats of primer, 3 coats of paint & 4 coats of clear. This works great on the hard plastic but on the soft be sure to use vinyl paint with adhesion promoter first. Regular spray paint will chip real fast if used on anything that's soft and flexible!
HndMeDnBroncoII
Pitt Meadows
BroncoII
the vinyl paint adhesion stuff works well u can use spray vaersion of base coat clear coat paint and just dont put the clear on the base coast paint matches up with a very good finish similar to the factory and then u can have any color u want made into a spray can though but the spray cans this way can be costly .
mlw20lu
bulldog adhesion promoter and primer and ur golden. simple as that
Z3CHYD
U.S. Military - Active
17
Lancaster, PA
3 front 5 rear
225/60R15
Jessie_D_S
FORD
paint
I used Dupli-Color High Performance Vinyl & Fabric paint after a bath in denatured alcohol and a scotchbright pad and a layer of primer
Loanranger
4
Puyallup, Wa
1972
Ford/
Fordzuki
2.9/2.3
Denatured alcohol+
gold scotchbright+
Bulldog (or similar adhesion promoter)+
your choice of vinyl and plastic paint
Do not use normal spray paint, it will turn to gel in the heat of a car. Use something designed for automotive interiors.
Primer is not neccesary, unless you have small imperfections smaller than a 180 grit scratch that you would like to fill and sand, which is not likely to turn out well on a textured surface.
The bulldog adhesion promoter is also a sealer, which means you can topcoat right over it with good results.
