P0102 P0104 codes 98 f150
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
As title says. 98 5.4L F150
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Get a new maf sensor? Or clean it?
8,370
P0102 Mass or Volume Air Flow Circuit Low Input
P0104 Mass or Volume Air Flow Circuit Intermittent
These are both "Circuit" codes, so it could be the MAF sensor itself has wiring issue inside, but it can also be wiring harness issue
So have a good look at the MAF connector, unplug it and inspect wiring for frays and connection for corrosion
And follow the wires as best you can looking for damage to the harness
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
My dad is still chasing his problem. I think he did a smoke test, but not sure. I copied this text from our conversation ---"Hey man, ask your forum buddies about a vacuum leak under the intake manifold. I've got an aluminum one and everything I look at are black plastic. I blew smoke into the intake behind the throttle body, it took a few seconds then the smoke comes billowing out from under the manifold. ?"
Is this enough info???
8,370
Must be a 1999 F-150 or 1999 engine they had the aluminum intakes
Seen here:
I would suspect a leak in that lower plastic plenum
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
Can somebody run this VIN, to see if his truck came with the PI heads or if he has had th PI conversion already.
1ftrx17l2wkc06796
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
Anybody got ANY idea about this, Should he be looking for a new Intake, or what?
Truck was born in July of 98,
8,370
If he saw smoke coming out from under the intake then he will need to pull out the intake and see where the hole/crack is
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Yea I'd pull it then determine if you just need gaskets or an entire intake. In my experience aluminum intakes dont tend to have issues so I'm betting it just needs a lower intake gasket. Or... theres a vacuum port underneath that you haven't noticed and that's what's leaking.
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
Thanks fellas. next beer is on my tab :beer:
Ranger850
4,691
Tallahassee Florida
Stock 2"
Stock
UPDATE: His troubles started after his truck backfired. He found some plastic bits under his hood when that happened, and the smoke test he did, tells us he has leaks. He is in the process of pulling the intake to see how bad the damage is. Thanks to all for the help and stay tuned for more.
8,370
Yes, backfire can certainly take out plastic intake parts, especially when they get older and more brittle
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Technically a backfire is from the exhaust... a fire from the intake end would be a queef?
8,370
I think people use the word backfire for either
Like Freeze Plug or a Starter Solenoid on the inner fender, you know what they mean even though the terms are not technically correct :)
"back" could mean not forward out the exhaust, so backfired through intake
Or it could mean it fired backwards to back of vehicle
alwaysFlOoReD
5,095
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I had to look up the definition of queef. I can see how you might relate that word to the sound coming from an intake....
So coming from the exhaust should be a fart?
