Oversized radiator for towing
dla
2007 Ranger XLT, std cab, 2.3L, 5spd man, 2wd
The stock radiator holds about 1 slurpee of liquid. I would like to "SuperSize" the radiator for towing. Where can I get a larger radiator?
07rangersport
Maple Ridge, BC
4.6
For what you can tow with that truck I wouldn't waste the time or money
Ranger5.0
Lindsay Ontario
ya, I kinda agree. the overheating issue may be related to the overloading of the truck maybe?
dla
I was really looking for some intelligent people who might know some manufacturers. But thanks anyway.
07rangersport
Maple Ridge, BC
4.6
Im the dummy?? I have a 4.0. Go get a truck with some balls. Intelligent people don't buy a 4 banger for towing. Buy a BIGGER truck. All I was saying was that for whatever that truck can safely handle, the stock rad will be FINE.
17,929
SW Iowa
+1, Ford did test these things at the factory. If you are having problems keeping the thing cool you need to get it fixed because something is wrong with it... or you are abusing it.
I have worked the snot out of my little 23 year old single row radiator in my Ranger, even with an auto it has YET to get hot.
Wicked_Sludge
43
Westport, WA
3-point-GO
its really unwise to insult the people you expect to help you. rather than calling people names (we're all adults here), you should heed the advise of people with more experience in these subjects than yourself.
ford used essentially the same sized radiator in your 2.3 as they did in the early 4.0's. if its enough to cool off a 220ft-lb v-6, its overkill for your dinky 154ft-lbs 4-popper. ive towed over 3,000lbs up 10% grades in june with my 3.0 and never "run out" of cooling system capacity. your going to be hard pressed to over-load your stock cooling system...just make sure you keep it maintained and it'll be fine.
dla
Really? You know this for a fact that Ford tested the Ranger cooling system by towing loads around in the desert mountains?
Ya, right.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
use the 4.0L radiator. it will fit. the radiator for the mustang will fit aswell, just not sure what years
dla
Well you've not towed much.
I used to tow a 3500lb trailer with a 1969 Toyota Landcruiser that had 135hp. It had a 4" thick radiator that must've held 3 gallons by itself. I towed all over Montana in the summer. Sometimes doing a whopping 20mph up a pass. I'm saying this because some of you weren't born when 143hp was a lot of power.
17,929
SW Iowa
Ya, right.
Volvo Arizona Proving Ground (VAPG) - Wittmann, Arizona
Volvo Arizona Proving Ground opened in 1985. The Proving Grounds consists of 1,498 acres (6.06 km²) located one hour northwest of the Phoenix Sky Harbor Airport at an elevation of 1,650 feet (500 m). Volvo Arizona Proving Ground is operated year round. The climate is of a desert type with low annual rainfall and low relative humidity. Daytime temperatures are high throughout the summer months. The winters are mild. Nighttime temperatures frequently drop below freezing during the three coldest months, but the afternoons are usually sunny and warm
http://en.wikipedia.org/wiki/Ford_Proving_Grounds#Volvo_Arizona_Proving_Ground_.28VAPG.29_-_Wittmann.2C_Arizona
Dunno why they call it Volvo now, in my '85 Ranger brochure they just call it the "Arizona Proving Grounds"
They put them thru the paces doing what they are rated to do so they avoid unneccesary warentee claims and bad publicity.
07rangersport
Maple Ridge, BC
4.6
Horespower means almost nothing when towing. It's the torque that really matters. Also that landcruiser is totally different than your new ranger. And probably came with a straight 6. Apples to Oranges. Did you not read anything that wicked sludge had to say (intelligent??) And How can you say I've not towed much?? Where does that come from?? You want to put in a bigger radiator?? Go ahead WASTE your money on something your truck DOESN'T NEED. And also.... I'M SORRY that I tried to save you some time money NOOB!!
dla
Thank you for the link. However, that land is flat and 1600' elevation, so I don't think Ford towed anything up a pass there. I used to live there.
