oil leak
ssny1088
Posted awhile back about the eec/pcm possibly losing power. Finally found a decent pin out diagram,though not entirely correct. 2" back from eec connector stripped wires and ran the 6 grounds, 2 ignition and 1 memory to bat. Ran good all day,so????? Anyway, came back from junkyard w/gauge cluster(has tach,My 97 2.3 5 spd man. for some reason didn't) and noticed puddle underneath,near drivers f tire. Pos. it's oil. Thinking (hoping) it's oil filter or sending unit. Mostly in front of filter but some on intake ,bat and brake master. Question is where is sending unit? Seen posts saying in front of filter and others saying to rear near intake? Truck sure is a PITA for only 62k orig. miles!!!!!:dunno:
8,372
2.3l Oil sending unit should be drivers side toward the back on lower head.
By the front tire would most likely be power steering "oil" or brake fluid
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Or your truck is spitting up oil through the dipstick tube due to excessive blow-by...
Put a rag around the dipstick tube if you can't find leaks anywhere else. Drive it for a bit...after checking oil levels...then check the rag for oil after the drive...if no oil could be from somewhere else...but...mine didn't always do it and I never did figure out what caused it...other than possible PCV issues...so check that also...maybe change the pcv valve (pcv stands for P Crankcase Ventilation ...can't remember what the P is for) and it allows for crankcase pressure to be released...otherwise your engine spits up oil..
ssny1088
leak
Thanks for heads up on location of unit. Too cold and too much fustration to mess w/today. Later in week. Did rattle test of positive crankcase ventilation valve when doing plug change a few weeks back,but will check on. Maybe I didn't get back in all the way and popped out? Will change oil filter as it's time anyway and maybe sender also and put actual gauge unit in instead of 7psi dummy and clean up mess and go from there. PS unit is full and oil is half-quart low so it's oil.:beer:
8,372
P = positive, positive crankcase ventilation.
PCV Valve should be closed when intake vacuum is high, and blow-by is low, idle, then open as vacuum drops and blow-by increases, acceleration.
Rattle means valve is free to move, but is by no means a definitive test, lol.
Replacing PCV Valve every other oil change is not a bad idea.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Yeah, keep an eye on it and what RonD said about the rattle test is true...mine rattled like crazy but didn't work worth a pooty.
Thanks for the rep! :icon_thumby:
I thought it was Positive but I wasn't...brain isn't working right sometimes and it probably doesn't matter to most...unless you put something totally wrong out there then everyone and his sister is on you like flies on a turd...
8,372
Yup, PCV valve = Pollution Control Valve Valve
Freeze Plug
Starter solenoid............on inner fender
Good Chevy or Dodge truck
All mistakes :icon_rofl:
ssny1088
solved
No work and warm so looked into this. Started truck and nothing obvious was leaking. Looked around pcv, crawled under to see oil sender and both were dry. Grabbed rag and wiped up what I could and for sh*** and giggles checked tightness of filter. Started again and had small shooting stream from filter. When I grabbed it must have opened up more. Guessing it's rusted under the grip material from the 4-5 yrs it sat.:beer:
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
:icon_thumby:
Good thing you checked that filter...I've never had one leak other than the one I didn't tighten properly...
Glad it's not your engine puking up...that is an expensive fix...:)
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
A little bitty hole in a filter can pump one hell of a lot of oil in seconds. I dropped a filter, still in its box, and put a little dent in it. Put it on and had oil all over the place in seconds. The drop put a little crack in the can. Learned a lot from that mess.
