No Tail lights
Rufus
Last night the Highway Patrol pulled me over and told me I didn't have any tail lights. I had left turn signals, hazard flashers, and brake lights but no tail lights. This morning I found the bulb on the right side out and replaced it but still no tail lights. The fuses look good but I don't seem to be getting power at the "Y" connecter behind the bumper. Does anyone have a diagram or can explain to me how to check this connector properly?
Rufus
Sorry, we are dealing with a 1992 Ranger
rtg143
ASE Certified Tech
61
Oregon
5.4l
Here it is.
Explorin94
Law Enforcement
Firefighter
EMT / Paramedic
19
Farmington Il.
"Y" connector as in trailer wirng T? Take it out and see what you have there. Do you have dash lights?
Rufus
I have that wiring diagram but I can't find a brown wire on the truck. There is no trailer "Y". Coming from the front of the truck there is a cable that ends in a "Y". From this Y the wire continues on to both tail lights and the license plate lights. The "Y' I am talking about is where you would add trailer lights without splicing wires with an adapter. No I have no dash lights and no front marker lights. Turn signals work, brake lights work, and hazards work. I have had the dash lights go out before and found the bulbs just needed taken out and put back in and they started working ?????
Rufus
I found the problem, now I have to figure out who's A$$ I need to kick. It seems someone thought it would be funny to remove the fuse for my marker lights. I checked every fuse and they were all good so I was going to check for power at the fuse block and when I located the position for the fuse, I checked rechecked and though huh, there's nothing there. Slapped a 15 amp fuse in the opening and presto whamo the lights work! So like I said I'm going to have to find out who took it out and kick their backside till I tire myself out. Those fuses don't just hop out of the fuse block on their own!!!
rtg143
ASE Certified Tech
61
Oregon
5.4l
Well glad you found it. Thanks for the update.
