No crank after explorer swap
NBraun
South Dakota
I put a 97 explorer 5.0 with a m5r2 into my 94 5 speed 2wd. This may be a dumb issue, but I'm having trouble figuring out. I don't currently have the pcm and engine harness hooked up, but I figured I would see if the motor would turn over. It won't turn over. I'm not getting any power to the sense wire on the solenoid. I tried jumping the clutch switch, but that did nothing, not to mention it worked fine before hand. I figured since the solenoid has nothing to do with the engine it would turn over. But I could be missing something.
Thoughts?
8,386
Should turn over
Ignition switch in START, 12volt----------clutch switch------(red/blue wire)--------starter relay on fender
No computer or anything else involved
12v does come from engine fuse box, did you swap in V8 fuse box?
In 1994 fuse box, fuse #1, 60amp powered the ignition switch
Does starter work if you give "S" post 12volts?
NBraun
South Dakota
I have power in the truck when I turn the ignition to acc.
I did not swap on the v8 fusebox.
If I jump the terminals the starter will spin.
8,386
The red/blue wire runs from starter relay to the large round multi-wire connector on firewall under brake booster
Connects to another red/blue wire in the cab that runs to clutch switch
Clutch switch has a 2nd red/blue wire, next to the 1st red/blue wire, that comes from ignition switch
Clutch switch has 3 switches inside, pins 1/2, 3/4, 5/6 are each separate switches
Each is closed/connected when clutch pedal is down all the way, and open/disconnected when pedal is up
5/6 are the two red/blue wires
Ignition switch(under steering column) only sends 12volts out on the red/blue wire when its pushed all the way to START position
The key operates a rod inside the column that pushes/pulls the ignition switch into its 4 positions, ACC, OFF, RUN, START
Called actuator rod
If key feels funny, it may not be pushing ignition switch all the way to START
Could be jumper on clutch switch didn't connect the two red/blue wires
Could be connection at the firewall large connector was damaged
Could be change in wiring harness disconnected red/blue wire in engine bay
NBraun
South Dakota
This helps alot! I will take a look at it tonight and see what I can come up with.
Thanks!
NBraun
South Dakota
Still no luck.
I bypassed the clutch switch at the actual CS and still no luck. I have two other wires, a LB/Y which is input from the pcm and a GY/R which is output to the engine controls, according to the diagram i'm using. I cut the red power wire going to the ecu to power the explorer ecu, and thought that might be the culprit, but I ran 12v to the pcm and still no start.
I suppose i'll keep futzing with it, it just feels like i've checked everything that it could be.
8,386
No PCM involvement on pre-1998 Rangers/Explorer, pre-PATS
Clutch switches other 2 internal switches are "neutral" sensors, used by PCM for REV limiter, cruise control module, and 4WD module(if so equipped) 4Low shifting
There is just the one wire from ignition switch to starter relay("S" post) on the inner fender, when that wire has 12volts, Relay is activated, and then starter motor is
NBraun
South Dakota
Right, I get this. I don't two red/blue wires at the c/s. I have 4 total, one is r/b, the other is pink. The other two are what I said earlier.
I have 12v going to the r/b wire at the clutch switch in the start position. I don't have continuity between the r/b wire at the clutch switch and the r/b wire at the solenoid.
8,386
What about the pink wire and the r/b wire at starter relay
Pink was used in some 1997s for the wire from clutch switch to the firewall connector, in that case the r/b would be from Fuse 24 in the cab fuse box, 10amp, but only has 12v at that fuse when key is in START
And this can also mean there was/is a Anti-theft system installed, a factory alarm with a starter interrupt relay
You would have Keyless entry if this was in place
NBraun
South Dakota
No pink wire at the starter relay?
I can't find a wiring diagram for a 94, I'm sure that would help things. I've been checking continuity and trying to find the wire that the r/b corresponds to inside the cab and can't find anything. I've checked the plug going into the cab and nothing. The only wire it has continuity to is another r/b wire that goes to an engine plug for the original 2.3L.
8,386
Pink wire is on the clutch switch and changes to r/b color wire at the firewall and r/b wire runs to starter relay
So test if pink wire has continuity to r/b wire at starter relay
NBraun
South Dakota
Problem solved, should someone ever need this for future help. Ford ran the solenoid wire through the engine harness plugs. There are two, a gray and black. On the black plug there is a pink wire on the truck side, this gets 12v on start. Cut this and splice to your solenoid wire.
I'm guessing they left this in the harness for auto trucks and just spliced them together on manual trucks in the engine harness.
