No brakes.
huwenfut
Kalapana Hawaii
Stock
Stock
Stock
My steering wheel was shaking when I applied my brakes. I replaced the rotors and calipers. Now I have no brakes. Pedal goes to the floor. I’ve bled the system numerous times. Rebled the master cylinder and still no brakes. What am I doing wrong.
rusty ol ranger
2.9 Mafia-Don
7,585
Michigan
177 CID
What year is the truck?
If its ABS equipped you might have air in the abs pump
franklin2
1,767
Virginia
Bronco II
Did you do both sides at once? There is a chance you got the calipers on the wrong sides. You can tell this if the bleeder is pointed down. The bleeder on the caliper should always be on top. If it's on the bottom, you will never get the air out of the caliper.
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
Could have got a pinhole in a brake line that you are not seeing. lay some cardboard underneath it while pressing brakes to see if any leaks show up. Your info shows an 82 ranger so it shouldn't have abs. I would suspect an old rusty brake line has a pinhole from tinkering with brakes. That's always my luck when working on brakes with rusty lines..... I live in the rust belt too though
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
huwenfut
Kalapana Hawaii
Stock
Stock
Stock
That was the problem. Switched them this morning and it’s working like a clock now. Thanks for the advice.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Upgrade to armored bumpers and aim at soft stuff.
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
franklin2
1,767
Virginia
Bronco II
The only reason I suggested this, I have done it myself. Have to watch those pesky rear wheel cylinders also, the same thing can happen.
