New rack and pinion Loss of power steering
dper299
New Jersey
Just installed a re-manufactured rack and pinion from auto zone along with new power steering lines. After bleeding the system and refilling with mercon 5 trans fluid & taking for a test ride power steering has gone away after 3 turns. Steering turns freely when jacked up in the air but once put down on the ground it is very tight and hard to steer. Is it possible that the pump has now gone bad? When you look in the power steering reservoir you see very little fluid circulation.
99 Ford Ranger 4x4 xlt 3.0 v-thaks in advance for help & suggestions
Also I have the pressure line in the bottom rack port and the shorter line to the cooler in the top port.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Is the "new" rack actually a remanafactured rack from autozone, advanced or the like?
dper299
New Jersey
Its a re-manufactured auto zone
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Then there's more than a good chance you got a junk rack. Most of the reman companies used by autozone/advanced do little more than paint old parts. The DOA rates are insane.
dper299
New Jersey
Just bled the system for a third time. The power steering pump only has flow under high rpm no flow at idle which explains the hard steering while stopped . So based on that I'm going to guess it's a pump problem.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Okie dokie
