kp3ft
- Jul 7, 2009
- Reaction score
- 0
- Automatic
I'm very seriously stressing out. What do I specifically do to remove the crankshaft sprocket without damaging the crankshaft position sensor? (I need to put in a new crankshaft oil seal) I unbolted the sensor but can't remove it because it looks like I have to draw the socket off first with a gear puller. Or do I remove the auxilary gear? In order to remove the auxiliairy gear, it looks like I have to remove the section that the belt roller wheel and power steering pump is connected to. I can't tell if removing that section is complicated or not; it almost looks like it's connected to the intake somehow?
All I want is to replace a freaking crankshaft seal, what is the minimum steps necessary?
